Currently reading:
Bathroom floor grout cracking
Discuss Bathroom floor grout cracking in the UK Tiling Forum area at TilersForums.com.
bluevin123
Hi,
Tiled a bathroom floor a couple of weeks ago for a customer. Plyed it out first with 12mm ply,primed it,used flexi addy and flexi grout and screwed down every 12 inches.
Few days later went back because the grout was cracking in places.
we went back and put more in,but last Friday he rang and said its cracking again.
So we going round tomorrow...Gonna get the old grout out and add GT1 to the grout mix to make it more flexilble and pour it in the gaps, apparently if we make it quite wet,it will go under the tile to fill any voids as well,if any..been advised by a skilled tiler to screw down every 4-6 inches for future jobs ,NOT 12.
Just hope this sorts it out,would hate to go back and rip it up,oh yeah they are porclain as well.
Does what I intend to do sound ok with you guys?
Cheers.
Vinnie.
:uhoh2::uhoh2:
Branty
Danny,
I agree with you completely! It's been done wrong but he may get away with regrouting it???
Kev
But the correct reply would be to tell him everywhere he has gone wrong.
If he went ahead and regrouted with a W/J grout and AD1, and that cracked. He then Came back on here for more advice, and you then tell him his ply was not thick enough. Would refund him his money for the extra grout and labour?
TilingLogistics
Danny,
His initial query was he intended to modify an already modified grout. I pointed out he couldn't. Ultimately it was only 6" of grout cracking. If I told him everything that was wrong he would have to rip up the whole thing. People come on here because they are looking for answers to solve their problems. If I went your route virtually every job would have to be redone. You have already said in other posts you are seeing this daily. How many rip it up and do it again???
Kev
Branty
Danny,
Kev
In this instance, if I was called out to this job, that is what would need to be done, and that is the advice, as a BAL employee I'd have to give.
So that's the advice I gave the guy.
As a professional giving advice to people that are looking for it, then that too is the advice you have to give. If the floor needs to be ripped up, then that is what has to happen.
I didn't even mention the fact he has voids under his floor, which should be solid bed fixed.
If some one asks for advice on putting a job right, I give it. As I said, if this guy had spent a few quid regrouting, and he came back here next week saying his floor grout had cracked again, what would you say to him?
Branty
as the song says Branty....'rip it up and start again'
IMO - you both have valid points but i think vinnie was looking for the quick fix in the meantime.:grin:
I agree Brian.
But when you do that, its important to point out what probably is the underlying problem. That way you're giving the overal picture, and let the person decide what he wants with all the facts. I was just trying to cover all the bases on this post. Not just repeat what other people have already said.
The D
In my humble opinion the advice given to tilers today should be do not tile directly on to plywood sub-straights. There are more than enough products out there that can do the job. You are risking a failure if you tile on to wood in the best of circumstances. Even if you have used 18mm ply and screwed at 6 inch centres and primed the under side and the edges of the wood and screwed the tong and groove floorboards to ensure there rigidity. You can even go as far as to ensure the joists are free from movement. You can do all this and still get a failure. Wood is unpredictable.
graham31
Yes see your point,but is this not changing what every tiler has been taught over the years?
Reply to Bathroom floor grout cracking in the UK Tiling Forum area at TilersForums.com
