Help! Tiled whole bathroom with Tubbed adhesive only to find out it’s not showerproof
In a bit of a nightmare here
We recently spent a lot of money having our bathroom re-plastered (plaster board and skimmed) to make the walls smooth and square ready for tiling
My dad and husband have been tiling it and have done a lovely job! (My dad has done it a few times but it’s my husbands first time)
HOWEVER.. popped to b&q with my husband today to buy more adhesive and when I read the tub it said only suitable for areas of intermittent wetness.. not suitable for showers! (The b&q shelf label refers to it as waterproof and so dies the description on their website but the tub says otherwise)
We have rang the helpline and the guy said it is waterproof but not shower proof (eh!?) but that it should be fine if it is sealed and grouted properly. And that he has told others this and known it used.
The shower in question is an over bath shower so it won’t get as much water contact as a proper shower but I’m still concerned
Is there some kind of sealent/waterproofing membrane type thing I could apply between tiles before grouting?
What would you guys do in my position? It’s our first house and don’t want any disasters .. but also don’t want to make them pull the tiles off and have to potentially buy new ones at £200!
The tiles are very well stuck on and not able to be pulled off
Any help would be massively appreciated.. I’m trying not to act too annoyed at their mistake as they’ve done a brill job and worked very hard and I don’t want to be ungrateful but the mood isn’t great between us right now!
Ohhh I didn’t mean to start a tanking war
I think Tanking is definitely worth doing.. probably every effort you can make to waterproof things can only be a plus point. However I really do appreciate the advice given that for many years it wasn’t done and bathrooms have been fine, as it has definitely put my mind at rest!
.. I even had my grandpa say he put his tiles on with poly filler which did make me laugh but they’re still on!
To be honest my original concern wasn’t even the Tanking it was the adhesive.
The walls behind the tiles are brick which is plaster boarded and skimmed over .. don’t know if that makes a difference but I saw it mentioned!
I’m off to a proper tile shop tonight to get the right materials so at least the rest is done properly
Thanks very much for everybody’s friendly and helpful comments and advice!
Never thought I’d find myself on a tiling forum and was wary that I might face a backlash of jobsworths telling me how wrong I’d done it but I’ve been really impressed with all your help.
... hopefully I won’t be back on here in a few months telling you all my bathroom has caved in
You obviously have trouble reading my northern writing , i take it you are female, as you like to bloody argue like a women
Sexist and arrogant. What a catch.
Let me explain my view point one last time. If you don’t tank your showers then I believe you do a poor job- wet rooms, domestic, commercial, everything.
Pushing my view point on people, I hope so. In fact, Australia, New Zealand and I believe Sweden, it must be done. It’s a regulation.
I'm sure it will be fine .
I never understand the viewpoint of needed to tank a wet room but not a shower. The only difference is the floor has a former and not a tray, there's still tiled walls in a shower. Most of the issues with shower leaks come from the joint to the tray leaking and soaking up the wall. If the wall is water proof then it can't happen.
Not sure if it makes much difference but my shower (in question) is over a bath not a wet room or a shower tray
Wow,what a arse, you need a sense of humour sweet cheeks:anguished:, and the only arrogant person on here is you my love, and I have two daughters and a granddaughter, and get walked all over by them, so I’m about as sexist as you are a really sound man (so not sexist at all, as you seem a bit of a penis, and probably work on your own all the time as no one will work with you)
And Just one more time for the little ladies on here who can’t read my writing or are just far to stuck up their own arses to be bothered to read it.
I have absolutely no problem with tanking, a good thing, yes,it makes people more money,does it need doing, not really in domestic showers which has been proven for decades(that’s a fact ) I’ve seen loads of tanked bathrooms fail, some on here, why is that ? ***** workmanship, as a non tanked bathroom will fail if it’s ***** workmanship .
How many tilers in this country don’t tank a shower and have never had a problem, I will bet anyone on here it’s a lot more than who do tank .
Ps luckily for me, I don’t give a flying monkey if you think I’m doing it wrong, I have absolutely no problems with my methods and have absolutely no complaints in over 3 decades , well apart from off the mrs
Bye
That goes without saying andy , I mean you never understand people’s veiwpoints:kissingheart::yum:
Sounds like the Lady doth protest too much.
The name calling didn’t take long though. It shows a lack of any substance in your argument.
Been nice chatting x
There’s no logic behind it at all. Shower trays average out at 40mm in height these days.
Also those who don’t tank domestic showers should also not tank any higher up the wall than the tape fold at the floor to wall joint on a wet room- if they do tank higher it’s another contradiction.
This is becoming way off ...
Someone should start another thread on tanking, maybe even a pole...!
The results could even be more interesting than brexit..!
Its true wgat they say about you on here, a know it all who thinks he is always right 🙂
I think I’m the only female on this thread and the only one not arguing!
ACTUAL ON TOPIC QUESTION:
Bal or Webber grout???
Nope, you’re the 2nd women, waligi is the 1st.
Only used webber grout, so id go tilemaster grout🙂
It doesn’t make a huge amount of difference. Out of the two I’d suggest that a shower above a bath is the less likely to require tanking.
As already mentioned, it will probably be fine. A point to consider though is making sure your Bath to tile joint is sealed before you install your shower screen, your shower valve shroud(s) is sealed to the tiles, especially important if a shroud sits on top of a grout joint. Shower tidy holes are sealed alongside any slider bar you might have. Also period checking/maintenance of the Silicon seals and grout is also worthwhile.
Out of the two I’d go with Bal. something like Microflex or Micromax 2.
Thanks for that. Will make sure to do all of the above. We have our tanking kit (Ardex)
For the bath and a grout sealing spray which we will use often
No problem, we have given our views on how it should be done so hopefully you can make an educated decision with future projects and I apologise for my part in any petty squabbling that I might’ve been involved in on your thread.
I'm confused now, is the tanking kit for another room or have you stripped back what had been done?
So we haven’t yet tiled down completely to the bath .. there’s still a row of tiles to go ( the one on the top edge of the bath) so I thought I may as well tank that part! And the walls under/around the bath
Bathroom Tiling Advice
Unsolved
Bbbecca7,
Lou,
Bbbecca7,
Lou,
