Hey mate, all good . Extremely busy.... Getting married again 🙂 Have new addition to my family- another dog. How are you?
You found it then haha :thumbsup:
Yeah I’m good Tony mate thanks.
Miss seeing your work here!
Well congratulations and congratulations, again! :thumbsup:
Thanks. Will post some … Have done some interesting wooden mosaics not long ago. They said it was first in the UK. So would like to hear opinion.
This is the result I got for a bathroom refurb. Tiling took 8 working days from 19-28 Feb. He said his cutting machine kept breaking because my tiles were 'good'. He enquired about why his machine was breaking at his trade store. He also tried to invoice me for 15m sq, when he decided to only do 2 walls (I had asked for all walls half-tiled). Aside from him lying about how many walls we agreed, and lying about the amount of tiles on my walls, is this a professional standard? Will I have issues with leaking through this cracking and patchy grout or tiles cracking or falling off?
image1.jpeg image3.jpeg image5.jpeg image4.jpeg image7.jpeg IMG_1192.JPG IMG_1202.JPG IMG_1193.JPG IMG_1148.JPG
It’s hard to tell, you have some cracked and missing grout and a few chipped cuts but wider view photos would help see the bigger picture.
Again, tiles must be faulty because they have cracked in 5 months of installation.
Few emails later getting the fitters method statement.
No, they have cracks because your "professional bathroom fitter" (turns out he's a general builder) has tiled a shower, without tanking, onto plywood!
Waiting for further images when the tiles are taken down.... or fall off!
EDIT: Exact reply from the builder:
"Your bathroom hasn’t been tanked, nor does it need to be, it’s not a wet room, we have used 18mm marine ply as a base, screwed in every 6 inches with 40mm wood screws, flexible adhesive (Mapai)
Flexible grout (mapai), corners and joints have been sealed with dowsil 791 flexible translucent Silicon before application of adhesive, we used a 6mm notched trowel."
View attachment 106794 View attachment 106795 View attachment 106796
What about the one at the bottom that doesn't want to be attached to wall anymore , is that faulty too because it hasn't stuck .
I guess it must be. Better get in touch with the factory and tell them to stop making tiles as an issue has been spotted by a builder. She has 5 more like that dotted around the base that she hasn't sent photos of. I've told her it should be condemned on safety grounds and there is no fix other than a full rebuild of the cubicle. Strangely enough, still not had any response from her or the builder yet.
As for marine ply or WPB, these days that don't mean shi....taki mushrooms. Wood + Water = Pop. Plain and simple. They haven't removed it from the standards for no reason.
Morning all
remember what was said regarding tiling on plywood.
One of my students was asking about why we use SBR & Acrylic primers instead of PVA so as i always confuse the the wording with SBR they googled it underneath the quote below these were a couple of the questions there.
SBR Bonding Agent. Construction Chemicals SBR is a white styrene butadiene co-polymer used to improve the properties of cement renders, screeds and mortars. Itis also used in conjunction with Construction Chemicals Tanking Slurry as a priming coat or tight render base coat.
Can you tile on plywood wall?
Can I Tile to Plywood on a Wall? While some types of plywood can be used in certain types of tile installations, use of the material has limitations. ... For wall installations, your real concerns are whether you want to use thin set directly on the wood and whether you are using an exterior or interior type of plywood.
Do I need to prime plywood before tiling?
The plywood surface will then be the surface to be tiled. ... So your nice new clean ply floor isn't so clean anymore and if it's not prepared properly prior to tiling, the adhesive will just go onto the dirt on the floor and might not stick! This is why it is better to prime it than not to
Public Thread!: Poor Tiling Workmanship by DIY and Rogue Traders
Dan,
ttt tiling,
Dan,
ttt tiling,
