Lip on tiles
N
Nasty nic
Hi all well did my first job today in tiles in the bathroom. Need some help for ideas . We have the standerd while tiles in our bathroom and wanted to replace them but because of the tiles going behind the sink and the toilet and the rad we thought that the job would we to big. So we took a row of white tiles out and put in a row of mosaic tiles. The problem we have now, is that there is a lip about 3mm on the mosaic tiles to the white tiles. Is there anything I can do to make it look smarter?
Is the lip caused by a fatter tile or by the amount of adhesive used. If the former then there's nothing you can realistically do short of digging out the wall.
you could use a listello boarder or trim, top and bottom of the mosaic...
YES THERE IS! SUPA PRO Mosaic Wall Spacers (Per Strip)
different story if he was mitre wizz user :lol:
People who use Sigma cutters, and people who drive Vauxhall vans, are not the sort of discerning professional that the Mitre Wiz was designed for. Those sort of people will always make do with a slap of plastic trim here or there, or a dab of Silicon to hide a poorly mitred external angle....
Tony you mean put a 45 degree angle on the mosaic blocks so it's flush with the whit tiles?
looks like dark emperador and crema marfil marble mosaic border which is 10mm thick, and ceramic tiles are 6mm thick. too late to do anything
that is what i thought, but was hoping i could make something or use some sort of trim just to make it look neat but i dont think it will look that bad after i have grouted it. my fiirst tiling job as well as had to take off most of the white tiles to swap the damaged ones also had to change the bath beading as the last person went OTT with sealent and was going black
yeah i know but there is not anyroom between the tiles, my GF keeps going on about tiling over the old tiles so it would be even, but i think it would look worse because of the sink, toilet and rad
Dear Nic, you were surpose to level the space with adhesive b4 laying the mosaic. Now check if it is possible to remove the mosaic alltogether without damage, carefully clean the adhesive , take note of the thicknes mosaic, then level the space let it dry then apply the adhesive and put the mosaic.
so you say the best thing i should do is remove the mosaic tiles fill in the gap so its level with the white tiles then lay the mosaic tiles?
Dear dealercity, the mosaic is thicker than the field tile. 🙂.
i have seen this in B&Q thought of looking at the 4mm trim then get a sharp stanley knife and cut the lip off that goes behind the tile and use the trim. think it might work if it fits
[DLMURL="http://www.diy.com/nav/decor/tiles/border-tiles-tiling-trims/tiling_trims/Homelux-Glaze-Ceramic-Effect-Tiletrim-White-L-1830mm-x-H-4-6mm-9277960"]Homelux Glaze Ceramic Effect Tiletrim White (L)1830mm x (H)4-6mm, HGCS TT 100[/DLMURL]
You could take off all the tiles, keep the mosaic and buy some other tiles 10mm+ thick and do over or call in a pro. Otherwise just leave it as is, grout it and be done.
Just an idea 🙂
well i do think once the tiles are grouted and cleaned it will make it look neater, was just trying to find away to make it look smarter. i dont think i have not done that bad for my first time.
2 choices nic..
remove and build field tiles to suit or leave as it is... as a first time job and seen as GF is giving grief..lol.. leave it be and grout to finish.. you know next time your mistake
, so crack on and enjoy.
Dave think i will leave it lol.
i can keep looking for ideas, i need to grout in the morning so i can then skim the walls in the afternoon then seal the bath as the grout should be dry then sand the walls once the sealent is dry to then paint the walls then skim the celling. once all that is done changed the bath panel and bathroom flooring. sometimes i hate being a man
Lip on tiles
Nasty nic,
Muse2k8,
Nasty nic,
Muse2k8,
