Porcelain Can you Silicon on top of grout?
Sefirah
please help I'm having a new bathroom installed and the tiler has finished his part and grouted everything.
The fitter said he will grout over the Silicon.
Just wanted to check this is ok?
I have a shower tray and a bath.
The bath panel is tiled, and where the bath panel reaches the lip of the bath is grouted and he said that doesn't need Silicon- it's a 5mm gap.
Though I've heard that due to movement it will crack so should be siliconed. But if so can I ask him to Silicon over the grout?
And around the shower tray - inside and out, this is all grouted and he's going to Silicon on top of it. Is that ok?
Thank you and confused...
Oh no I feared as much.
It's so difficult as how am I going to tell him I know better than him when he says it is fine to Silicon over the grout?
He's not going to be happy .. and I'm not convinced he would not scratch anything either, as he already has :-(
Is there a maximum gap you can Silicon?
I'm just wondering if the reason the tiler grouted everything is he left too large a gap?
Otherwise why would he have grouted everything? He rest of his work was excellent...
I know it's 5mm under the bath rim but I don't know about around the shower.
So I have to ask him to remove all the grout from around inside and outside the shower tray?
Can he partially remove it or does it have to be completely empty?
Aye, gap should be depth of tile, remove from the junction between tray and wall, also internal corners of shower area.
(Change of wall direction)
I'm sorry I'm totally new to this and don't understand the jargon you've used, please spell it out for me!
Am I going to need to ask him to remove all the grout entirely everywhere or just in some places?
So for example, under the rim of the bath, can he take a bit of grout away and Silicon then?
What about the outside of the shower tray where it meets the tile floor?
I have to understand it exactly so I can tell him what to do as he's so different to what he wants to do.
I just can't see how he can remove all the grout without scratching anything!
The junctions between different surfaces are called movement joints. EG between the shower tray and the wall, at the vertical corners in the shower, where the bath butts up to the wall tiling, where floor tiling meets wall tiling etc etc.. These should not be grouted but left OPEN and siliconed over, preferably with sanitary Silicon such as DOW785. This allows for movement at different rates. It is quite common for some traders to grout the area then Silicon over but by doing this, they are creating a 'rigid' movement joint, which is wrong.
I see thank you.
Well all of that has been grouted, so that must be the way they do it like he said, grout it and Silicon over it.
To resolve this what should I tell home to do?
Surely it's going to be too much work and risk damage by asking him to take grout of in all those areas?
Is there certain areas I should definitely insist on him removing grout prior to siliconing?
Iva attached photos showing grout all around the shower tray, bath, and where tiles meet tiles in the corner of two walls.
Am I going to have to ask him to remove all of this grout? And is it actually possible without him damaging anything?
IMG_9829.JPG IMG_9832.JPG IMG_9833.JPG IMG_9836.JPG IMG_9837.JPG IMG_9838.JPG IMG_9839.JPG
I know this is not exactly the answer you were looking for, but you might consider getting a professional mastic man in to complete the task. Get your guy to remove all the grout from the transitions explained above, then get someone in that only does Silicon work for a living.
They are clean, fast, and above all very very neat. It will also lift the finish of your project.
Silicon work can make or break a job, it'll either look excellent, or very very bad.
It's something I always push for with my clients, because they always so much better than me.
And it's worth every penny, in my opinion anyway.
Thank you, I didn't know they existed!
And if trust them more to know what needs to be siliconed.
Would they take out grout if not all had been removed do you know?
It wouldn't be something they do as a rule, reason being, to keep costs to clients down they're in and out in a very short time. They have to lump jobs together in a day, to make it worth their while visiting. So there would be at least an extra cost. If you're happy with that, then they may.
But don't hold your breath. 🙂
They must wear their underpants on top of their trousers!
At the end of the day it's up to you and you can leave it as it is and hope for the best. If the shower tray is grouted in, which it is, sooner or later stepping on and off it will crack the grout and eventually water will penetrate the background behind the tiles and ruin it. I bet he didn't tank it either?
Silicon the corners over the grout. There will be no problems. Previous poster making a mountain out of a molehill. If the grout cracks the Silicon won't.
Porcelain
Sefirah,
The Brown bomber,
Sefirah,
The Brown bomber,
