Sefirah
Showing different thicknesses of grout around the shower tray:
Discuss Can you Silicone on top of grout? in the Tile Adhesive / Grout Advice area at TilersForums.com.
It wouldn't be something they do as a rule, reason being, to keep costs to clients down they're in and out in a very short time. They have to lump jobs together in a day, to make it worth their while visiting. So there would be at least an extra cost. If you're happy with that, then they may.Thank you, I didn't know they existed!
And if trust them more to know what needs to be siliconed.
Would they take out grout if not all had been removed do you know?
They must wear their underpants on top of their trousers!I know this is not exactly the answer you were looking for, but you might consider getting a professional mastic man in to complete the task. Get your guy to remove all the grout from the transitions explained above, then get someone in that only does silicone work for a living.
They are clean, fast, and above all very very neat. It will also lift the finish of your project.
Silicone work can make or break a job, it'll either look excellent, or very very bad.
It's something I always push for with my clients, because they always so much better than me.
And it's worth every penny, in my opinion anyway.
The one I use does Ian, saves my life all the time.They must wear their underpants on top of their trousers!
Reply to Can you Silicone on top of grout? in the Tile Adhesive / Grout Advice area at TilersForums.com
