Travertine- bal wide joint superflex or slurry grout
AGT
Hi lads, can anyone clear this one up, do I just use a normal grout like the bal superflex or a slurry grout, if so what does the slurry grout consist of?
Cheers:thumbsup:
Substrate is a concrete wich I have primed with bal sbr, I then had to put self leveler down(ardetex). I've used spf White adheisive bal, and the patten is opus romana.
Bascily as you have just said...a sloppy flood grout that pours and spreads into joints ...usually for very tight joints etc or can be handy when tiling with thick stones that need a full grout joint..
UK Tiling Forum; UK
AGT,
AGT,
AGT,
AGT,
