New bathroom - Acceptable tiling?
G
georgechi
Hi all,
I've got someone doing my bathroom and yesterday they finished tiling. I've been going through the result and I'm not impressed with the quality.
Can you have a look and tell me if I'm too picky?
My issues:
- Some of the tiles are chipped (average sized finger for scale)
- In the far areas (far corner and top edge) they're not cut off straight.
- You can see one that's glued with a lot of adhesive and that changed the line on the wall.
- In a corner they don't match the height.
I've seen a lot of comments around how the grout will fix things. Would that apply to me? Would these issues be less visible through grouting? We are looking at a light grout (silver/ light grey).
Thanks,
George
IMG_1852.JPG IMG_1851.JPG IMG_1850.JPG IMG_1849.JPG IMG_1848.JPG IMG_1847.JPG IMG_1846.JPG IMG_1845.JPG IMG_1844.JPG
Thanks for the advice. Is there a measurable standard by which you can judge the quality of the work? Like lippage? Is there a tool that's used to measure this on walls for an objective judgement?
Thanks,
George
Indeed there is George.
Lippage is measurable in relation to the joint width, but like all facts and figures they often escape us at that very moment in time when they are needed most. So I'm unable to quote exact requirements, however, I'm sure it's about 1mm in a 3mm joint width or close to those figures.
Flatness of finished areas should not exceed
+/- 3mm in 2Lm in any given direction. (That one I recall).
Is this kind of problem common?
Only when non professional tilers are allowed to run amuck.
If you're unlucky you could end up hiring a bad professional tiler and that's unfortunate.
It's really down to you to research your potential tiler, or indeed any tradesman. That is the only way you can potentially protect yourself from this kind of issue.
Always get more than one estimate if you don't have a recommendation to go on.
Ask to see a portfolio or website, should have one or the other.
Ask to go along to a previous project and view it, or visit his current job.
These requests are not unreasonable, and any good tradesman will be only too glad to show you work he's previously completed.
Thanks for your feedback. I thought I exercised my due diligence, but clearly I should have done a lot more. I did ask for recommendations through friends, saw his website, reviews on checkatrade, facebook and google, but didn't ask to see up close some of his previous work.
Hopefully, this thread will help others in the future.
PS: Is there a tool to measure that?
Here's the result. There's still some work to be done and he'll be back next week to rectify.
Couple of questions:
- Plenty of places where the adhesive wasn't cleaned properly and it's sticking out through the grout. How acceptable is this? Is there any tolerance for this that the trade allows?
- Two chips that I could see. Is there an acceptable number of chips per square meter that the industry allows?
- You can't clearly see it in pictures but some of the tiles are not level. This is why I was asking about lippage.
- You can see the shower line where tiles don't merge straight. With grout it looks better compared with the initial photos I posted.
What's reasonable for me to request without being a nitpicker?
Adhesive again - ignore hole - will be fixed.JPG Some more adhesive.JPG Chipped corner and adhesive through grout.JPG Adhesive again.JPG More adhesive.JPG Chipped and adhesive.JPG Overview 2.JPG Adhesive through grout 2.JPG Adhesive through grout.JPG Overview.JPG Dodgy corner and adhesive through grout.JPG Broken corners result.JPG Overview shower corner.JPG
View attachment 91679 View attachment 91680 View attachment 91681 View attachment 91682 View attachment 91683 View attachment 91684 View attachment 91685 View attachment 91686 View attachment 91687 View attachment 91688 View attachment 91689 View attachment 91690 View attachment 91691
Safe to say that myself and probably every other tiler on this forum wouldn't leave a grouted finish like that with remnants of adhesive left all over the place. I clean my grout joints as I go before the adhesive sets. Anything missed is removed before grout is applied. Not acceptable in my frame of reference.
The Silicon work is questionable and the fact that some of the crosshairs on the grout lines are several millimetres out is again not acceptable.
If you're handing over cash for a job you should only be doing so when you are 100% satisfied. Imo it's not nitpicking at all. You wouldn't pay full price for a car that had a big scratch down the side of it.
Id give him the opportunity to rectify everything that's needing fixed if he refuses then I wouldn't be paying full price. Have a tiler quote for remedial works and deduct from final bill. Furnish him with invoice from tiler and deducted payment. Fair terms in my book.
@georgechi - Tiling is a finishing trade and as such the tolerances are strict.
As previously advised and to answer your Thread title - Acceptable tiling? - NO!
A decent Clerk of Works would condem most of your highlighted concerns so don't worry about trying to find standards of acceptance.
If it's chipped, it should be out.
If it's not level, it should be out.
If adhesive shows through grout, it should be removed.
If there are holes in grout, they should be filled.
Etc.
There are too many Jacks who think they can tile, but we are only looking at the surface! What preparation was done? What tanking around shower? What adhesive? Did he tile straight onto the plaster and how long had it been dry?
Can you look at that every day?
Etc.
Pretty sure not one wall saw a straight edge prior to installation.
I may be misunderstanding your statement, but the work contracted was to redo the whole bathroom, including walls, plastering etc. If the walls were not in a proper state for tiling, that's something he should have corrected.
Thank you all for your feedback.
I'll raise all my concerns with the builder on Tuesday. It annoys me that people don't hold themselves to a high standard and makes me feel like I'm the bad person for raising these problems.
Now the issue is, if this is his best work and can't possibly do better, do I ask him to contract a tiler himself? I do feel bad for all the wasted work and materials and getting a tiler myself doesn't seem fair.
Don't feel bad. If thats the best he could do then he should have held his hands up and said he was no good at tiling before wasting all the materials. That would have been you're opportunity to get a professional.
But still, give him a chance to see if he can fix it. If he says no, he needs to be paying you back to cover the remedial costs. Whether it be removing a few tiles or stripping them all of.
Point I was making. He has failed to take adequate steps to ensure a high quality job. Earlier images showing where has packed out tiles with adhesive demonstrates that.
I certainly wouldn't be recommending him for his tiling "expertise". It is a shame that you've been let down like this. That's the inherent difference between a tiler and a "tiler" a tiler knows how much tolerance he has in terms of flatness of substrates a "tiler" will wing it.
Certainly not bad for raising any issues with any tradesman who you're paying to carry out works. I'm sure if you were underperforming at work there would be some kind of procedure to address this. It's no different. You have hired him and put trust in him to carry out a job which he has assured you he is qualified to do. Clearly there's been some misinformation here. Standard procedure in terms of you hiring someone else and deducting from his bill if he's not able to rectify himself. At the end of the day it's whatever you are willing to accept.
Not sure if thats an external corner shot (and if so its location in the room) but I've seen those with extremely sharp edges, and rarely uniformly neat - would those experts on here suggest a trim or 90 degree joint ?
Yeah hate to say it but I agree, rough as it comes. The man has no pride in his work. And shouldnt class himself as a tiler. He didn't advertise as handy man did he you know the type can lay bricks plaster do basic plumbing, electrical tiling and roofing.......never trust them guys.
Funny thing is , tiling is probably the hardest trade to get right , but second to painting and decorating , the one that most people.ignore or take for granted.
Tiling is the face of any project , not an afterthought , when will people learn
Finishing trades get left all the rubbish too. Yeah the tiler will fix that. Yeah the painter will sort that. All trades should take pride in their work.
Like Bruce lee once said "I don't fear the man who's practiced 10000 kicks once I fear the man who's practiced one kick 10000 times" no I've not been drinking it makes perfect sense. Stick to what you know and do it right.
Hi all,
My issues:
Thanks,
George
View attachment 91620 View attachment 91621 View attachment 91622 View attachment 91623 View attachment 91624 View attachment 91625 View attachment 91626 View attachment 91627 View attachment 91628
uncalibrated slate tiles not the best to buy i personally wouldn,t have taken the job on
looks like your tiler should buy a level next must have put the cut edge as the leading edge.live and learn they say atb in getting it resolved
Wow mate that really is poor job,hope you get it all sorted and get the job rectified. But I guess it does pose the question would you get a tiler to build a house? I wouldn't be able to sleep at night if I left a job like that.
Hi all,
My issues:
Thanks,
George
I would ask for my money back..that is terrible work
Hi all,
My issues:
Thanks,
George
Looks like he snipped the "cuts" and closed his eyes and guessed the mitre angles..poor,very poor work
Sorry but if the Tiler doesn't rectify his work. Hold back the payment the workmanship is far from acceptable,and if you have already made payment ask for a full refund.
Bathroom Tiling Advice
Unsolved
georgechi,
Italy,
georgechi,
Italy,
