Hairline craks in SLC
V
vrytir
Hi guys,
I came with another problem. I use mapei Ultraplan renovation screed to self level my floor with cable UFH. And now I found hairline cracks in it. Does it mean my subfloor was not good enought and I can start again or is it normal.
Subfloor is WBP 18mm, mapei ultraflex, 6mm insulation board, then the UFH cables and now screed. I put quite a lot of noggins when installing WBP.
For the floor it will be ceramic tiles 300x300, using mapei ultraflex as adhesive. Not sure about grout, is there some "flexible grout"?
Or do I have to start again from scratch?
What is you opinions, please?
I prime it with Primer G and it is about 10mm-12mm thick. This ultraplan screed could be up to 30mm thick.
It was 4.5l per 25kg bag and deflection? Well I am big guy 20st roughly and when I put my laser leveller on the WBP there was some movement, but when my better half did the same there was just slight move.
Think mapei recommend using eco prime, unsure if this would be a factor in what's happened though
Could just be drying shrinkage. Pictures might help
Did it crack before or after you walked on it and are the cracks in straight lines or squiggly ?
We supply and use this all the time and over timber Eco Prim Grip must be used,,,i did talk to the tech guys this week and Eco Prim grip gives a chemical and mechanical bond to what ever you apply it to,,,Primer G would not have been man enough to use over WPB
and the pictures
are the cracks starting from the same point on the floor? could be a weakness at that point
Looks like a combination of shrinkage cracks and movement in the boards, as with Dave, does it sound hollow when tapped?, coz thats a whole new ball game.
So should I take it apart and start again:yikes: I plan to use mapei ultraflex adhesive, which is super flexible, wouldn't this help?
Or could I put another layer of SLC? Would this help?
I also find that current layer of SLC is kind of "AERO chocolate" bubbly, I guest this is problem.:mad2:
Would another layer of SLC sort both problems (bubbles and cracks)? And then use Mapei Ultraflex adhesive.
vrytir,
James bond,
vrytir,
James bond,
