A
Algy
Oh and the primer I was recommended by the original flow screed layer is Ardex P51 - any thoughts on that?
Discuss 4 Year Old Gyvlon (anhydrite) preparation advice in the Canada Tile Advice area at TilersForums.com.
In this instance what dilution ratio (if any) would you use if you were using say, SBR
Just seems be an important part of the job which can really go t*ts up,if not done correctly.
And how do you measure this mythical 1mm. Sorry but it's rubbish. I've heard everything from 1mm through 5mm to one adhesive rep who said you have to sand until it's too hard to sand further and if you get through to the pipes the screeder has to replace the screed.
You are simply sanding off any loose friable Laitence with loose and friable being the key phrase. You don't scratch off with a screwdriver, you don't scrape off with the corner of a paint scraper, you don't bang it with the edge of an old chisel. Once the surface is sound stop sanding. This could be as much as 1mm but as little 100 microns. It's not measurable in depth terms. The requirement to expose aggregate is a myth. The screed is porous enough to accept a suitable primer e.g p51, p121, prime plus, apd, ar and many others.
The most important elements are make sure it's dry enough and where possible use gypsum based adhesive
Many thanks to those who have replied. It has helped. I guess it's an area both of differing experiences / opinion and maybe a number of different ways of achieving the same thing - you can see how I could get confused.
But I will do the light grinding (glad to hear 1 mm may be more than needed) and use probably P51 as the original screeder suggested, or ask carefully why the profession that I will have tile the floor, thinks another primer is better.
I'll also have a decoupling mat and see if the tiler agrees on a gypsum based adhesive for the mat and then cement based above mat to stick tiles with.
Can't do much more.
Reply to 4 Year Old Gyvlon (anhydrite) preparation advice in the Canada Tile Advice area at TilersForums.com
