Discuss Tile water absorbtion experiment in the Canada Tile Advice area at TilersForums.com.
Q
Qwerty
Following on from the discussion in another thread about not fitting ceramic tiles in a shower/ bathroom I have decided to conduct a little experiment.
I plan on testinghow much water tiles absorb.
I have 3 tiles to test-
-Glazed ceramic (10mm)
-Soft glazed Grade 3 Porcelain (11mm)
-Full bodied Grade 5 Porcelain (10mm)
Each tile weighs 304 grams so the water absorbtion will be easier to see and calculate as a %.
I will submerge the pieces for 24hrs then remove, wipe down excess and weigh. I will record each weight and then boil all 3 pieces for 15 mins. Somebody suggested water absorbtion for Porcelain is under boiling water so in the interests of fairness I will blast them for 15 mins to see if that makes any difference.
This could be a total failure and prove nothing but I have a feeling not.
Let the experiment commence!!! :D:)
Tile 1
Tile 2
Tile 3
Tiles submerged at 8pm last night....
And no, a Rubi wasn't used to cut Tile 2...... I had to chip of a gram to make the weight even !!!!!
Andy Allen
1,318
Gloucester
Are you totally submerging them or just one end..?
BTW .....good on you and look forward to the results.
(Hope you had a white coat on, ear defenders and safety glasses)...:)
Q
Qwerty
Haha, no I forgot the white coat. White pants count? :D
Yes, tiles fully submerged (you can even see the bubble on the edge of Tile 1) and No, scales not stuck!!!!
F
Flintstone
I've left off cuts of ceramic outside before and when I've gone back to them after a few rainy days, you could see the moisture in them from the face, behind the glaze, be good to compare that ceramic to a dry ceramic for appearance
Reply to Tile water absorbtion experiment in the Canada Tile Advice area at TilersForums.com
