Discuss Sand And Cement As Adhesive? in the Tile Adhesive / Grout Advice area at TilersForums.com.
It's called old school tiling, I use this method a lot, learned it in US, it's called '' Jersey Job'' if I am not mistaken, there's lots of skills involved as well. It's kind of hard to see in these pictures the portland /cement, sharp sand but this job is done the ''Jersey Way". Use it especially for large stone installation. I am the old school from head to toe, LOL.
Jersey Way. Works a lot better than the adhesive does. Loving it!
Well perhaps you could impart your knowledge with the forum then @detroitMi and do a thread for us?
I'm sure there would be a lot of interest.
Diggy
Sand and cement fixing = proper tilers,how many on here can do it ? Remember we can use adhesive but can you fix tiles with s&c
I can , learnt it right at the begining of my career as modern adhesives were starting to come in. A skill I'm glad I paid attention too , as I've used it a handful of times to some smaller jobs , quarry tiles mainly. Turned up on one job about 15 yrs ago to tile an outside porch , the concrete sub looked like it had been laid by Mr S.Wonder . There was S&C in the back of the blokes truck so did it with that ( 8" Quarries , lovely size and sorely missed ) , came up mint . Of course its other advantage is you create falls as you go and install gulleys.
For the OP , building paper used to be put down as a form of movement layer ( mainly for larger installs like communal shower areas etc ) , never did sand myself.
Still a top method of fixing imho , in the right situation.
Brief method. Semi wet screed , trowel up some moisture/fat , sieve on neat cement , trowel over , lay on tiles , sprinkle over dry S&C and gently brush into joints ( this not only grouts the tiles but also stops them wandering too much when beating ), sprinkle on a little water , beat down with beating blocks ( 4x2x15 for 6" quarries ) ,align , clean off , grout whats left to fill when set ( sometimes joints are full depending on size of joint , so final grout may not be needed )
Works for me , been a while tho'
Diggy :0)
Spud
you can do wall tiling with sand and cement too there are several different methods thin and thick bedding
here is the thick bed or hand fixing method as it is sometimes called
One Day
QUOTE="GaryTheTiler, post: 801673, member: 4720"]laundry room in an old peoples home , plasterers left the walls in scratch coat so I decided to fit the tiles the old fashioned way , hadnt done it for several years so wanted a bit of practice[/QUOTE] you do realise that you've made removing them at some possible future date, rather a headache for someone don't you?!
The D
Ste-G
View attachment 79660 View attachment 79661 View attachment 79662 View attachment 79663
This takes me back, soaking the tiles in a bin full of water over night, getting them out and stacking them to drain in the morning ready for fixing. Great job for the winter months, I can still feel the chilblains now :coldsweat:
I
Italy
That pic brings back memories of labouring on the old boys when i was a kid i hated getting the tiles from the bottom of the bouch, come to think of it i hated every thing about S&C work lol
oh my god that memories ....
hate even now
Brian the Tile
you do realise that you've made removing them at some possible future date, rather a headache for someone don't you?![/QUOTE]
Like s..t to a blanket lol
Reply to Sand And Cement As Adhesive? in the Tile Adhesive / Grout Advice area at TilersForums.com
Lowpaul22
