Blunt Tool
No that’s my preferred method I don’t like the other way and he can do whatever way he wants to achieve resultsDid you tell him to snap the board he might find it easier doing it the opposite way?
Same here on 12mm, cutouts in 6mm also, just make sure ur outside and wear a maskI just use a grinder...
You might be interestedI use ply 90% of the time
For once no hb = hardie backer and ply for his 90 % of the time lvt jobsAre you on the wind up Luigi ?
What blade? I find any grinder blade I use on hb doesn't last long at allI just use a grinder...
ATS .. porcelain blade..What blade? I find any grinder blade I use on hb doesn't last long at all
I use a sponge when cutting 12mm hardie
I use hard northern spongesIt's that soft you can cut it with a sponge?
