Discuss Builders using Hardiebacker boards in the Tiling Advice | Tile Forum area at TilersForums. USA and UK Tiling Forum
Blunt Tool
98DA7103-B900-4177-99A0-A20465EE9457.jpeg 46A9775F-A2CF-421F-90E9-C607FC6696A5.jpeg 3CC913BB-28A1-471E-84BC-EF8A9E9A027E.jpeg 83EE5650-736B-4781-9502-457EF91B21E0.jpeg 3ED931FE-D83D-4CF7-B6BD-1824B83C2C66.jpeg well after years of trying to convince one of the builders I do work for he’s finally ditched the plywood and is now using Hardiebacker boards. He’s now a convert and is going to use them wherever tile is required. I showed him in a small bathroom today how to glue and screw them, I could have told him 12 screws is all required per sheet but he’s used to 150 centres so just left him to it. He is going to get the foam https://www.tilersforums.com/forums/tile-adhesive/ as he is a builder and too lazy to mix up addey clean tools buckets etc but I’ll cut him a bit of slack.
OP
Waluigi
Did you tell him to snap the board he might find it easier doing it the opposite way?
OP
Waluigi
I do use HB when I use Rigid Tiles. Will probably have a few more encaustic jobs this year so more HB unfortunately.
Reply to Builders using Hardiebacker boards in the Tiling Advice | Tile Forum area at TilersForums.com
mmcdon47
I've Disabled AdBlock
