Flexible Bucket Liners - Market Research!
A very valid point to be honest.
I do see where you are coming from but the buckets themselves have a fairly finite life and get thrown out. Generally we leave the adhesive to dry in buckets over night and knock them out on the side of a skip the next day. We usually get around 5 or 6 mixes out of a bucket this way before we end up holing the flexible bucket (maybe we should buy the more expensive ones rather than the £5 ones). In addition, we need to have separate buckets for mixing adhesives and grouts and plastering really to avoid contamination. We end up with an awful lot of buckets really. In addition, cleaning out buckets uses quite a lot of water which is very environmentally unfriendly too!
With liners you can get away with one bucket per tiler to be honest, covering grouting, plastering, tiling, whatever you want. A 2mm liner on each mix will massively extend the life of the buckets.
I think that the liners (which would be made from recycled plastic) would both extend the life of the more expensive buckets and be less wasteful than throwing these buckets when they get holes in them.
o
fair points well made... Perhaps they could be made of s biodegradable "plastic"...
There is nothing in the patent application that says it has to be made of plastic to be honest. The more I think of the silicon idea that's been mentioned the more I like that. It would be a bit more pricey but being able to let the stuff dry and just turn it inside out to remove it all seems like it would be brill. It gets rid of the environmental stigma attached to throwing out plastic, even if it is recycled stuff.
Personally I hate spending money on something to just throw away. ....I make my buckets last ages as I clean them after every mix...and I would be interested in someting that made that process easier..
[MENTION=11022]cr0ft[/MENTION] I think you've got the seed of a very workable patent, I'd stick with pursuing the idea, I think andy's idea of being able to turn them inside out is great.
Thanks all. I've had a look at the bucket glove. At the moment it's only available in a 300mm diameter by 300mm high bucket which is not even big enough to fit a tiling trowel into to be honest.
Those ones are around £20 each and you would need 3 realistically. I think the larger ones that are supposed to be coming out soon are for their own 30L buckets and you could imagine them being around £35 each.
I'm not convinced they would work with flexible tile adhesive either. Certainly my attempts to knock flexible tile adhesives off a flexible bucket don't work very well!
Guys, those of you who said you might be interested if the product ever did come to market, I would be really interested to know what price you would be willing to pay for a pack of 10 liners. They would be made out of 2mm thick plastic and definitely stand up to a mixer paddle knocking them around, based on the prototype ones we've tried already.
I'm also going to investigate whether it's possible to make it so that the plastic liner can be reversed inside out and used a 2nd time too.
Personally I think the best thing about this is that it is throw away. That should be your usp.If you can get quality that will last a few mixes at a good price, I think it will work.
as for other trades.
plasterers and bricklayers will not spend any money on tools. Plaster doesn't go off and stick like rapid set. Bricklayers just use a bucket to put their entire collection of tools in.
plumbers ( me) do not mix much, and if they do they just chuck the bucket.
i think there's more possibilities to this, i.e. Food manufacturing, where they mix products in buckets and need a clean liner each time.
2 mm ? That's as thick as a bucket!
on a trial basis I'd probs fork out £15 for a pack of 10, if they proved good I'd possibly pay more in future, if they turned out to be lemons well £15 aint that much to loose.
Cheers, I need to pay you a retainer to keep coming up with these ideas lol!
Imo if your making it disposable it going to have to be really cheap.....or I would just carry on cleaning out my buckets.....the only thing I buy thats disposable are gloves and they cost around £7.00 for 100 that works out at 0.07 p each .....for a bucket liner that you just throwing away would have to be coming in at well under 50 p each
I see the theory but in practice, my labourer cleans out the first bucket while I'm using the second one. That's what he does, as well as knock up mixes, fetch tiles, remove rubbish, put kekkle on etc etc. In other words, cleaning buckets costs me nothing so I wouldn't buy them. I'm sure that some would buy them but not sure you'd get the volume to get the cost low enough.
Not sure I'd buy them, I'm using standard set more and more,I only wash the bucket out at the end of the day.
Personally I can't see it taking off, not sure the bucket glove has either, but I ain't no Alan suger so I wouldn't listen to moi [emoji41]
Sounds like a good idea in theory, but how strong are they going to be? Would they churn up on the mixer wisp?
Fair enough. I'll give them a go when they're ready, you never know, I could be your Norwegian salesman ;-)
Go on dragons den with it you might get some investment. ....at the very least free advertising. ..
Even the tight arse scot might part with some money. .lol
Careful there, I am a Scot 🙂
Problem is that I'm struggling to see a bigger market for them than just tilers if that makes sense! Usually there is a good reason why something hasn't been done already!
You can get a black bucket for £1.50 now which lasts a decent length of time! Having said that these Weber fast set flexible with 25% extra was going off very quick the last couple of days and I was cleaning out 2 often and the buckets may not last very long.
However as I may mix up 10 - 15 buckets a day I'd rather use 4 buckets and throw them away then say 15 liners for £7.50 (@ 50p each).
But good luck and I'd certainly try them.
How much more tiling could you do in a day if you didn't have to clean out 10-15 buckets per day though?
Where can you get a black flexi bucket for £1.50? I will buy them instead if you can let me have a link/vendor!
Black bucket for £1.50 from BQ ( I didn't say flexi) but this is a better quality bucket than the £1.00 one they also sell.
I use the bal buckets and get them for £3 a pop. I have had 7 for the last 6 months and they have went through everything from grout to adhesive to slc. The more and more I try to keep them ridiculously clean the more time I waste, although I do keep them very clean.
As said previously, I seem to be using standard set more and more mixing two buckets up at a time due to the size of the tiles. Floors are generally rapid set.
Good luck with the venture pal !
cr0ft,
cam_low,
cr0ft,
cam_low,
