OK. So I'm pulling together my shopping list.
RUBI TX-700 or RUBI TX-700-N - Still can't decide. Seems strange that the standard version is more expensive than the N version
Adhesive and Grout Whisk
Gorilla Tub - Medium 26 ltr
Gorilla Tub - Small 14 ltr
SBR Bonding/Admix agent - (Everbuild) - What's the coverage on this stuff? Do you use it for mixing the adhesive as well (rather than water)
3 mm Long leg Cross Spacers x 1000 - I want the same size tile spacing on floor and wall. Is 3 mm too small?
Rubi Stainless Steel Trowl 10 mm x 10 mm notches - the tile is 10 mm thick.....so 10 mm notch? How about the 10 mm rounded notch?
Rubi 160 mm Bucket trowel
Rubi soft rubber grouting trowel
Washboy - this seems expensive. Is it really worth it?
Rubi General Purpose Nippers
Stanley Chalk Line
Red Chalk
Rubi Professional Knee Pads
This little lot is gonna cost £500+ And I think it is far from complete! There's still the hole cutters, wet saw, etc
by the time you have added adhesive and grouts, sealants and wet saw etc to your list assuming you can get a good price on the adhesive you are going to touching close on a grand if not more.......have you had any tilers give you a quote? bearing in mind the timescale in which it may take you added to what you will spend it may be worth enquiring.
chris
Hi there,is there anyone who maybe can lend some tools in the area???
this would keep the costs down as long as you looked after the tools ! a lot of us carry too many tools at times.lol.
Good luck with all too.
chris
I've already bought the adhesives and grout......based on the recommendation from Topps. It went very much along the lines of "just bung what we need on the bill". I think we've got fast-setting flexible adhesive and flexible, ivory grout.
Stanley Chalk Line
Red Chalk
Dont need to mix the primer into the adhesive, just get single part flexible and mix with water (instructions will be on the bag). A 5 litre tub of primer mixes 3:1 water: primer (20 litres) and should easily cover 100m2. As for the wash boy, cross that off your list if this is likely to be your only job, just fill a bucket with water! Don't forget half a dozen sponges for grouting. Good luck!
3mm spacers are a nice average if you want the grout lines to be the same on the wall and the floor, I usually use 2mm on walls and 4mm on floors. Using a 10mm trowel is what i would use on the floor but a 6mm trowel for the walls is fine (both square not rounded notch) with a 6mm trowel you will get about 8m2 of tiling done per 20kg bag with a 10mm only 5m2. Maybe due to the size of the tile use the 10mm all over, but not necessary imo.
why would you not use a solid bed trowel on a floor Brian??
So it looks like a round notched 10mm is OK for the floors. Is something smaller more appropriate for the walls? I believe I read somewhere that the notch size should reflect the thickness of the tile.
Your walls are brand new and should be straight and true, I only use a 10mm on the walls if ther are alot of ups and downs. The main aim is to get maximum coverage on the rear of the tile, no voids etc. Only my opinion though and like i said earlier due to the size of the tile a 10mm is a safe bet
Maybe worth while putting a couple of expansion joints downstairs if you are going in and out of a few rooms.
Are you sure you want a rapid set adhesive ? you may be better with a standard set flexible, longer working pot life but obviously it will take longer to set, next day as a rule of thumb, 10mm minimum on the floor and back skim the back of the tile with the flat edge of the trowel, I would also use 10mm on the walls with your tiles, but that's personal choice, 8mm minimum in my humble opinion.
Yes, I wondered about that as downstairs will have wet underfloor heating. I was going to leave a small gap all the way round the bathroom floor and fill it with mastic. For downstairs, I was going to do the same, hiding the gap beheath the skirting board. I wanted to avoid an expansion joint across the width of the floor unless it was was sufficienty discrete not to notice.
Oh, the plumber and the spark started on site today. The pipe runs have started and I don't think it's gonna take him too long before the bathroom is ready for me to start. The delivery of the tiles has been confirmed for this Friday. But I still need to get the hardibacker, the water proof membrane (for round/under the shower) and the threshold thingys for the entrance to the bathroom and round the window. The tiles are mock travertine....I was going to get travertine but was put off by the high maintenance, sealing, etc. So I may put a strip of real travertine mosaic tiles around the wall. Then again, I may put in a strip of brushed stainless steel detail instead.
Well Topps only recommend the fast set with porcelaine for some reason, so that's what we've got.
I guess I don't want to use the rounded 10mm notched trowel on the wall......so can I get away with square on the walls and floor and just buy the one trowel?
a few ongoing photies would be nice as the job progresses, might be handy just in case we see something that can avoid disruption later down the line:thumbsup:
Incidentally, I'm not entirely familiar with forum etiquette. Can someone explain the use of the thanks button? I seem to have been thanked twice and yet I've only posed questions, not answered them.
Hmm. OK. Actually, posts of that sort are something I do a lot. Take a gander at my useful posts pages....a collection of threads I have written on the What Hifi site which aim to help others with DIY electronics, woodwork and IT. You'll find the page here - What Hi-Fi? Sound and Vision - My Useful? Threads (Sorry if I have broken any house rules posting that link. I will remove it if I have).
if you see the orange bar beneath a comment/post, there's a thumbs up icon with thanks written next to it, you just click that to thank someone for their post that you've found helpful/agree with:thumbsup:
OK. Got the hang of that! Sorry.....I've not seen that feature on any of the forums I frequent.
I think within the spirit of a good thread, we can let it remain
Are you going to lay all these tiles brick bond? Keep any cuts you have at all times as im sure you will be able to utilise them some where along the lines. Maybe if your looking for ideas for the bathroom you could ask for particular photos and maybe we could put some pictures up for you.
Yep. Brick bond. I guess that makes it harder!
Always looking for ideas.....what sort of thing do you mean?
My shopping list at Tradetiler is at £700+. Do you think I might be able to negotiate a discount? I've noticed (on other threads) there is a discount for trade.
I doubt it, but his service is second to none and he will price match genuine prices:smilewinkgrin:
While we're on the subject of Trade Tiler, I wonder why he dosen't sell adhesives? Its still a great site though, my first order arrived today.
Sorry to hi-jack!
DIY Tiler - 90 sq m of large format porcelaine tiling making me nervous!
DIY Tiling Forum
PJPro,
Dan,
PJPro,
Dan,
