Underfloor heating between joists
Simon Dale
Hi all
Just looked at a job where builder wants to put down 22m chipboard over joists then Ditra. I said nooooo. The heating system is wet on a polystyrene board with aluminium trays screwed to joists. I have mentioned giffa flooring. The joists are 400 centres so could probably use the 18mm. Any advice on this would be helpful as the builder will do whats best for a change. 🙄🙄 05a3b681-59a1-4306-90c9-173cb86040f3.jpg
Sounds like a job for Hardibacker, No more ply, Pro Ply or that Dukkaboard XL
I know for a fact that Pro ply is designed to go above UFH systems as I’ve read the technical data sheet. Not entirely sure on the others although it’s widely known that HB is OK above UFH.
Would have to be a thicker board though which limits some choices
Im not in Hardie good books at the moment 😀😀😀
I always bleat on about this, but just use Femacell flooring. Gives great conductivity for the underfloor and can be tiled straight onto.
I’ve done this numerous times, with no failures.
Ditch the ply
Is it thin porcelain, normal porcelain or stone? Use Tilemaster anti fracture mat no matter what, it’s thin and for hundreds could save thousands.
Not too sure about no fixings into joists tho
Heres the reply ?
Good Morning Simon,
Thank you for sending us the photo- so for the GIFA floor system it is a floating system and doesn’t need to be screwed into the joists. Knauf flooring edge strips are to be used on the perimeter of the system to absorb any movement and stop the transfer of sound through walls if the floor does move/buckle. A anti fracture mat would substantially help, other than that this is all we advise for the GIFA floor.
Thank you for your enquiry,
Please do not hesitate to contact us should you need any further information.
Kind Regards
Sam Bunting
Technical Support Trainee
Tel. (+44) 08000 304 135
www.knauf.co.uk
Follow us on twitter @KnaufTechnical
Anti fracture to help with a buckling floor . It just shows these guys dont know what they are on about and just make it up as the go along
Simon Dale,
Neillybeg,
Simon Dale,
Neillybeg,
