Discuss Underfloor heating between joists in the Canada Tile Advice area at TilersForums.com.
Waluigi
Might be worth checking to see if it’s definitely suitable for UFH.......beneath.
Chalker
1,058
Tadcaster
I always bleat on about this, but just use Femacell flooring. Gives great conductivity for the underfloor and can be tiled straight onto.
I’ve done this numerous times, with no failures.
Ditch the ply
Blunt Tool
Is it thin porcelain, normal porcelain or stone? Use Tilemaster anti fracture mat no matter what, it’s thin and for hundreds could save thousands.
Not too sure about no fixings into joists tho
Simon Dale
1,108
Maidstone
Heres the reply ?
Good Morning Simon,
Thank you for sending us the photo- so for the GIFA floor system it is a floating system and doesn’t need to be screwed into the joists. Knauf flooring edge strips are to be used on the perimeter of the system to absorb any movement and stop the transfer of sound through walls if the floor does move/buckle. A anti fracture mat would substantially help, other than that this is all we advise for the GIFA floor.
Thank you for your enquiry,
Please do not hesitate to contact us should you need any further information.
Kind Regards
Sam Bunting
Technical Support Trainee
Tel. (+44) 08000 304 135
www.knauf.co.uk
Follow us on twitter @KnaufTechnical
Anti fracture to help with a buckling floor . It just shows these guys dont know what they are on about and just make it up as the go along
Reply to Underfloor heating between joists in the Canada Tile Advice area at TilersForums.com
