New Member - Question re: removing tiles
tpwuk
Hi everyone, great mine of information this place. I've been picking up loads and loads of tips....so many thanks for sharing. 🙂
I'm an enthusiastic DIY'er and got lot's of time on my hands so am able to take my time when attempting new tasks. My latest project is to re-tile my ensuite. I started to remove the old tiles from my shower enclosure which is a studded wall construction. I got all the tiles off one wall but it totally wrecked the plasterboard.....it was a simple enough job to replace the plasterboard and make good but I'm a bit relucant to do the same on the other two walls. I'm thinking about just tiling over the existing tiles but the only problem I can forsee doing this is that the old tiles have a border tile running the length of each wall which is about 3mm thicker than the rest of the tiles. What's the best way to deal with this difference in size? I thought about grinding the border tile down but wondered if there's a less dangerous approach...I kind of like all my fingers attached to my hand! ;-)
Many thanks in advance and kudos to you all!
Glenn
its easy to replace the plasterboard, tiling on tiles can be done but lots of ifs and buts and more expensive materials, but if you have to smash the border tile out and fill the hole with cement based adhesive or an old tile ect😛ete
hello glenn and welcome to the forums mate............I would just remove the whole lot mate and start afresh........we will help you through the process if you so wish......:thumbsup:
Hello Glen, you've already took tiles off one wall, you'd be better off carrying on taking them off the other walls...as Dave say's "start afresh"..Mark.
Aye you've done one wall propperly so it's a pitty to go sub-standard on the rest of the room.
Hi & welcome.
As it is a shower area, I would agree with the consensus and get the existing tiles off. I would suggest replacing the damaged plaster board with a backer board such as Hardie backer or Wedi as they will give better water proofing characteristics, too.
Good luck.
Thanks for the welcome guys and advice thus far. 🙂
My only concern about removing the rest of the tiles is that one of the walls backs onto the airing cupboard and it conceals a lot of pipework. I kind of don't want to risk damaging any of the pipes and complicating matters.
Am I just being a wuss? lol
Hi and welcome to the forum.
Always start fresh, tile on tile can cause weight issues, meaning that with tile on tile you will have double the weight on the wall and if your not sure how well the old tiles are fixed there is a possibility the old tiles could give way under the extra weight of the new ones.
tpwuk,
TheWrightTiler,
tpwuk,
TheWrightTiler,
