Oops, will try to edit that, its definitely adhesive. rapidset flexible adhesive.
dont pour the adhesive , lay the bag flat on ground put a stanley blade right along the middle denoting to halves then put your hands underneath at top and bottom of cut line and pull up you should have 2 half bags stand up nicely opened already for you![]()
Thanks for the tips, tiles are done, apart from one 'gap' thats more like 8mm as opposed to the intended 5mm, the effort wasnt bad for a first time tiler (and the bad 'gap' is behind the toilet pan so cant see it).
Waiting 3 hrs now then will grout 🙂
