Concrete panels on bathroom walls?
Jonathanb
Hi, my first post on here. I am looking at fitting thin concrete panels on my bathroom and shower wall. Has any one used them before?
The ones I was looking at are either Concreate or https://livingconcrete.co.uk/concrete-panels
The livingconcrete type say you can use them on a wall by fixing with tile adhesive but not much more imformation.
The Concreate say they need to be glued to the wall, but does not mention if they can be fitted with tile adhesive, spacers and grout.
P.s I’m not a tiler, I’m a carpenter
Cheers
John.
Getting there 😀
John..
Good work 🙂
Make sure you clip those speedfit pipes down so they dont bang around under sudden pressure changes. If that happens when its all boarded & tiled it will drive you mad!
They don’t do the sizes I need 🙁
John.
You need a reaming bit, (finger bit) mark out the hole and either use the biggest bit you can find
120-125mm then use the reaming bit to enlarge it.
Something like this.
Vacuum Brazed Finger Bits M14 - ATS Diamond Tools - https://www.atsdiamondtools.co.uk/product/vacuum-brazed-finger-bits-m14/
Or just use the biggest you have and stitch drill and grind rest away.
The only one that @Pro Tiler Tools have is the Montolit to my knowledge and it’s very expensive and aggressive, and if this is your one and only time you’ll use it then the Montolit is an expensive bit.
Nice job, Jonathan.
Did you use Reuters for your German gear?
I spend about £5k per month with them and my tile supplier every month. No idea what I’m going to do from March next year.
Bathroom Tiling Advice
Unsolved
Jonathanb,
Jonathanb,
Jonathanb,
Jonathanb,
