Discuss Concrete panels on bathroom walls? in the Canada Tile Advice area at TilersForums.com.
483
North yorkshire
Started the tiling today :D
John
4E97B363-E39E-47AD-9C86-3D57DDD6C58B.jpeg D8C9D50E-D503-4662-A0D9-1A5DF364E93B.jpeg 7BA7B1CD-B62E-4CB7-A569-2807BD735156.jpeg
They don’t do the sizes I need :(
John.
You need a reaming bit, (finger bit) mark out the hole and either use the biggest bit you can find
120-125mm then use the reaming bit to enlarge it.
Something like this.
Vacuum Brazed Finger Bits M14 - ATS Diamond Tools - https://www.atsdiamondtools.co.uk/product/vacuum-brazed-finger-bits-m14/
Or just use the biggest you have and stitch drill and grind rest away.
The only one that @Pro Tiler Tools have is the Montolit to my knowledge and it’s very expensive and aggressive, and if this is your one and only time you’ll use it then the Montolit is an expensive bit.
Reply to Concrete panels on bathroom walls? in the Canada Tile Advice area at TilersForums.com
