Hi we are Large format tile installers. With over 20 years of tiling experience . We have currently purchased all equipment needed to install large format tiles and completed the specific course last year. We have completed numerous jobs and are now looking to expand our business.
Please do not hesitate to contact me or my
Business partner Matthew.
Thank you
Thank you
Hi i am in involved in a large project in the Cotswolds and the job has been delayed so our tiler cant change his dates. It’s a large job involving some large format tiles. Could someone get back to me asap.
Thank you
Hi, I have a quite a large barn conversion in South Devon. The Tiler we had booked has had to drop out due to illness and we are struggling to find other large format tilers. Require floor tiling through out and 2 bathrooms + WC all with large format tiles (2700X1200) please call if you can help.
Dear Sirs,
We are building an indoor Spa pool/Gym in Cheltenham and would like to use 120cm x 278 x 6mm porcelain tiles on the walls. Its about 100m2 of tiling. Hopefully ready to tile in August.
Thanks.
Thank you
Dear Sirs,
We are building an indoor Spa pool/Gym and would like to use 120cm x 278 x 6mm porcelain tiles on the walls.
I have attached preliminary drawings showing the interior and also a rendering to give you an idea of the complexity of the job.
1. About 100m2 tiling
2. The drawing shows a very rough layout of the tiles. Please feel free change this to reduce cuts and waste
3. I would like the window and door reveals to be tiled. Please advise on this and also if you can chamfer or add a trim.
5. We should be ready for tiling in August?
6. Please quote for everything except the tiles which I will supply.
A ballpark figure is fine for now.
Best regards,
Sebastien
Cheltenham
  • Hetton Tile.pdf
    Hetton Tile.pdf
We have a wellness area starting 29 th mayAnd are looking for an experienced installer of very large format tiles. Will be offering the highest rates. Travel and accommodation if needed Nesr Blackburn. Lanc’s 07966 500 100
Large Format Tilers Looking for more work all areas
Cyrus Caven,
John Lancaster,
Cyrus Caven,
John Lancaster,
