Is this job being done correctly
When he comes back tell him you have sought professional advice and that he should have checked to see if bath was level and walls were plumb before he started whole tiles from either. Ask if he has put any form of bonding agent on loose old patchy plaster walls before tile adhesive. Also has he even set out to see if there is a nice size cut at ceiling and floor or is it just a lottery to see if he is lucky! Tile grout lines should be nice and even, plumb and level and no tile edge sticking out past another. Adhesive should be applied to walls and tiles coated on the back to compensate for poor existing walls. Tell him to stop, and go and find a reputable tiler preferably one who can give you references of past work, be prepared to pay a little extra to get a professional job!
At least he used decent adhesive but that's where the decency ends. Poor job all round and poor tiles too unfortunately it sounds like a case of you get what you pay for
Thank you for all your advice the tiler is related to my partner which is what made it so awkward.
I have told him not to go any further and have a real tiler coming tomorrow to look at it.
So hopefully should be all sorted going forward, not without upsetting a few people though unfortunately.
If he's not upto the job he shouldn't really be taking it on! Does he do tiling for other customers outside the family circle ?
It's like a lot of posts - the tiler is not a tiler but a friend/family - then the tiles are poor quality and it's the material at fault, no preparation just slap them on, then next it will be, but I've paid him in advance - what action should I take!
Come on people - get real - and check them out first!
these sort of tiles from diy outlets are often floor tiles sold as wall tiles or vice Versa
Hello,
I would not rush to blame the tiler. Or "tiler".
It depends on what you hired him for. And for how much you made the deal.
Different qualities has different prices and costs.
A good lying of tiles could take the double of time as a regular one. Consequently, must cost the duble.
But if you want to spend X money in a job, the tradesman will adapt at your budget, and might skip important steps, and I don't blame them.
1. Support looks awful. I don't know if you hired the tiler to tile or to take off old tiles and prepare the wall. So, if, for example deal a price of xx pounds by square meters, this price could not include leveling the wall. Even a good tiler could not make a great job on bad support, with bad tiles.
2. Tiles doesn't look to calibrated for me either. The same, you can not level the tiles if there are big differences between tem. You can play with, but not too much, especially if using small spacers ( of 2 mm, as I can appreciate)
So, first of all, you should give as the price that costed you this job, than I want see the opinions of the good tilers that commented here.
EDITED.....
Prices and bad language are not acceptable on this forum.
ADMIN.....
Once tiles have been stuck to a wall, it's basically tough luck. I work for a tile distributor and have worked for a few in my time and all terms and conditions state that no complaints will be entertained once the tiles have been fixed, pretty much standard practice across the tile industry.
As for the calibration comments. All tiles are manufactured to EN14411 standard. Therefore a 30x60 porcelain is allowed a tolerance of 0.5% across both the length and width. This equates to a 3mm difference across the length and 1.5mm across the width. Not ideal because this allows some of the not so good manufacturers to put all sorts in the boxes.
Hello,
1. Support looks awful. I don't know if you hired the tiler to tile or to take off old tiles and prepare the wall. So, if, for example deal a price of 15 pounds by square meters, this price could not include leveling the wall. Even a good tiler could not make a great job on rubbish support, with rubbish tiles.
This post is so wrong in so many ways I don't know where to start..!!
Antony Davies,
JMC tiling,
Antony Davies,
JMC tiling,
