Skirting boards cut or tile against ?
Ben Ross
hi guys just wondering what your opinions on this are, this is for floor tiles
do use butt the tile up against the skirting boards
or do u use a multitool and cut out the bottom of the skirting and lay tile under ?
I always try and remove skirting, but as local tiler said, not everyone is happy with such things so just butt upto. Definitely cut bottom of architraves off tho
Had to price a job where he wanted about 180m of skirting's bottoms cut so the tiles would slide under nicely and there was sockets on the skirting, nobody knew where the wire runs were.
Didn't get the job 🙄
pain in the backside with skirtings on, but needs must.
Last 4 or 5 floors ive done have had them fit before tiling.
My favourite was the 130m2 limestone floor, went and priced it befor it was plastered, went to tile it and it was fully decorated with skirtings on 😡😡😡
This one im doing now, they have just had the house fully decorated and re carpeted, now they are redoing the kitchen area last, makes life much more interesting 😉
my present job, 200m2 stone with wet ufh. Chippie wanted to fix all oak skirting first.
no problem I said, I'll put the 10mm expansion joint up to the skirting then rather than hidden under it 😉
Done quite a few new builds were the skirting has just been tacked on (nails not driven through) quite handy, save a lot of time get perfect measurements/cuts and even better for wooden floors as there's no horrible trim...
oh I love doing wooden floors, so quick and clean
That's a shame😀
Interesting thread, and thought worth mentioning that there are skirting profiles available in the Schlüter-DESIGNBASE range which may be an option for jobs where you're asked to finish the skirting detail.
Schlüter®-DESIGNBASE-SL: Schlüter®-DESIGNBASE-SL | Function | Schlüter-Systems - http://www.schluter.co.uk/schluter-designbase-sl-product-detail-0-60868.aspx
Schlüter®-DESIGNBASE-CQ: Schlüter®-DESIGNBASE-CQ | Function | Schlüter-Systems - http://www.schluter.co.uk/schluter-designbase-cq.aspx
Samples can be requested from the office on 01530 813396 or by emailing [email protected].
To find out once new products are released along with gaining access to the exclusive events, competitions and promotions then sign up at www.schluterandu.co.uk.
Great idea that , its always bugged me that joiners have alsorts of profiles to put up against skirting when putting floors down, and wood is much easier to cut and fit that a blinking porcelain tile .
Think i may want a sample 😉
Ben Ross,
widler,
Ben Ross,
widler,
