Ian
I'm thinking of investing in one for peace of mind on new slabs. Can anyone recommend a particular model or a link or two. Thanks Bri
what type of slabs bri..?
I just ask as you need a different type for Gypsum based ones..
On cement screeds Bri, i just do a sweat test.. easier IMO..
I think they are ok for walls if it's a cheaper one but for a 75mm+ screed then you will have to move up to a really pricey one.. could be 400 quid or so..
I did have a look on ebay earlier and the prices range from a few quid to a few hundred. Its not something I know a great deal about, but if a good one is that much I'll stick to a good old bit of polythene!
One I've had demonstrated ( and considering) is the Protimeter Surveymaster. As well as having the contact measurement and the probes you can measure the moisture up to 20mm below the surface without drilling. With this you make an instant assessment on the moisture within a slab the theory being if it's dry enough 20mm down all is well. It is pricey tho certainly over £300.
A 20mm down reading isn't much cop on say a 75mm screed is it..:lol: the damp will be further down and will still rise when covered.... Sweat the bugger out i say..🙂
the only way to test concrete subfloors is with a hygrometer like protimeter hygromaster, protimeter mms or tramex cmexpert either by drilling floor and putting in the plugs or with a hygro box. All other damp meters are for wood but caan be used on concrete to give you best places to test. Rh% is the measurement british standards dictate otherwise you're liable for a failed floor. This should be done for every job and takes minimum of 48 hours to test.
check with british standards it's the only test they will back up
hi i have a £35 one ,not sure wot make ,but all i can say is that we had a guy turn up and do a test for us useing one that cost £2500 and it give the same reading my one did ,lol
On what substrate though ?[/QUOTE
concrete floor
