Ian
I'm thinking of investing in one for peace of mind on new slabs. Can anyone recommend a particular model or a link or two. Thanks Bri
Discuss Moisture Meter - Test Floor Screed Moisture Before Tiling in the America area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
what type of slabs bri..?
I just ask as you need a different type for Gypsum based ones..
On cement screeds Bri, i just do a sweat test.. easier IMO..
I think they are ok for walls if it's a cheaper one but for a 75mm+ screed then you will have to move up to a really pricey one.. could be 400 quid or so..
I did have a look on ebay earlier and the prices range from a few quid to a few hundred. Its not something I know a great deal about, but if a good one is that much I'll stick to a good old bit of polythene!
One I've had demonstrated ( and considering) is the Protimeter Surveymaster. As well as having the contact measurement and the probes you can measure the moisture up to 20mm below the surface without drilling. With this you make an instant assessment on the moisture within a slab the theory being if it's dry enough 20mm down all is well. It is pricey tho certainly over £300.
A 20mm down reading isn't much cop on say a 75mm screed is it..:lol: the damp will be further down and will still rise when covered.... Sweat the bugger out i say..
Reply to Moisture Meter - Test Floor Screed Moisture Before Tiling in the America area at TilersForums.com
