P
Perry
would take to long imo
Discuss Tiling around windows without trim challenge in the UK Tiling Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
the window has not been centred correctly, granted.to be fair Richard, the one without trims doesn't do justice 'cos ot the slithers and brick bond:smilewinkgrin:
The mitred cuts are a hell of a lot slower,do look great when well done.
I have done a few mitred and a couple for sure i underpriced.
you must be an old guy dagger, i seem to remember when tiles used to come with mitred edges the boxes were marked "jolly" is that right ??if mrs does not want trim you have to mitre,
and if you are doing it yourself with no time constraints the two "jollys" aka "mitres" can be greater than 45 degrees so cut the tiles without touching the glazed edge then rub the angle greater than 45 without touching the glaze.
it depends on what material you are working with how long it takes but it will work in the end!
Reply to Tiling around windows without trim challenge in the UK Tiling Forum area at TilersForums.com
