N
Neil 28
Hello everyone a very happy new year to you all!! It’s been a while since I last posted!!
Currently renovating my bathroom and now at the stage of tiling. However I need some advice in sourcing the correct adhesive for the floor. I have removed the old floor boards as they were cracked and warped and installed 18mm wbp ply instead. I have also replaced two joists and supported the floor with extra noggins. The joist centres are 280mm. The floor is sound with no deflection, I used my laser level hooked to a tripod to measure the movement and there was very little only if I jumped.
The plan is to install 6mm hardie backer board to the plywood prior to fixing the tiles. The tiles will be 10mm porcelain and I wish to glue the hardie to the plywood and then screw down to the joists.
My question is which adhesive do I use for gluing the hardie? The products I have narrowed down are:
Ardex X7001
Ardex X7R
Ardex X78
The X7001 is designed specifically for wood based boards and sheets, and after speaking to Ardex technical services they recommend this, but it is very expensive compared to the others. I know mapei keraquick can be used but only if mixed with their latex solution, which brings the price up to X7001.
Can I get away with using the other two products or anything else besides the X7001? Also I will be screwing down the boards anyway, so hence can I just get away with using any flexible adhesive? What would you peeps do?
Thanks in advance for your advice and support.
Neil.
Ardex X7001
Ardex X7R
Ardex X78
Neil.
