Tile water absorbtion experiment
What I wish to know is what is actually failing and does saturated tiles matter if the adhesive and structure behind are built with this in mind.
My post suggests the situation that the tile, grout and adhesive is saturated (mimicking the test completed).
Some adhesives quote the adhesion strength after immersion in water, which do drop. However those designed for the role appear to match nominal values for lower priced adhesives.
So to answer your question what are the issue with saturated tiles? Adhesives capable appear to be available ?
The number of failed installations that you have come across must be immense I am interested in what's failed based on the topic of saturated tiles.
Post your question in a new thread. This one is going off on a tangent
It's completely related to wet ceramic tiles nothing else - I wrote the post.
I want to ensure to output of the tests are linked to the effects. Makes little sense otherwise.
It wasn't a request. I will do it for you if you don't. You want to conduct a test then crack on. I am actually interested in the results, but this thread is perfect because of its simplicity. You are over complicating it.
@Canyondust you seem intent on coming across as some kind of know all scientist with a question for any response given to any question asked. We on this forum for the large part earn our money by installing tiles under the advice and direction given to us by companies like Isomat, Ardex,Mapei,Bostik,Kerakoll,Schonox,Botament and Istarmac but to name a few. If you are serious and truly confident in your questions and objections then why don’t you publically challenge the thousands of chemists and engineers that these companies employ who set the standards for us to follow, or is that a fight you’re too smart to pick?
I believe I am asking yourselves questions and the information I have is from the suppliers.
I have no evidence or reason to doubt the information they have kindly provided, including how it's obtained. I have not objected to any manufacturer data unless you can show me otherwise.
My questions are based on the tests at the start of this thread, which showed the ceramic tile absorbed more water. The questions are why is this a problem?
I fail to see asking what issues you have come across is 'no it all'. Again it's just being offensive to a person wanting to understand where to pay more attention to in future. I do not see why wanting to improve an installation is such a problem.
No complication involved simply a wish to understand what the issues are with the results. A test that shows a possibility of more water absorption. Why is this a problem? Can these problems be mitigated ?
Here is one problem . If you have porous grout with a ceramic tile you can get shadowing around the edge of the tile . Wouldn't happen with porcelain .
There you go again!!!!!
That is your question right there. I will create your thread shortly.
Qwerty,
Dumbo,
Qwerty,
Dumbo,
