Tile Adhesive & Grout Classifications S1 S2 C2 Etc Explained
U
united
TILE ADHESIVE AND GROUT CLASSIFICATIONS
I always get mixed up or forget what the number/Letter
combinations for the classification of adhesive and Grout mean and everytime I try to look for a guide on here I can never find one so I thought I would start one off myself.
Please feel free to add to it or correct me
Type C - Cementitious (Cement based Adhesives)
Type D - Dispersion (Ready mixed / Tubbed)
Type R - Resin (Epoxy)
TILE ADHESIVE CLASSIFICATIONS
Extra characteristics are described by the numbers and letters below
1 - Normal Adhesive
2 - Improved Adhesive
F - Fast Setting
T - Thixotropy (Reduced slip/ Slip Resistance)
E - Extended open time
G - Grout
S - Elasticity / Flexibility / Deformability
S1 = Deformable (Flexible)
S2 = Highly Deformable
TILE GROUT CLASSIFICATIONS
  • TILE ADHESIVE ANS GROUT CLASSIFICATIONS
Spot on with your summary! The adhesion test (C) is the most difficult to pass because the adhesive is put through a series of tests, freeze/thaw cycles, water immersion etc and then the bond strengths are measured after 28 days. C1 is greater than 0.5 N/mm2 after all the different cycles and C2 is greater than 1 N/mm2.
Adhesives classed C2 may well have some flexural properties because you do need a reasonable addition of polymer to achieve the C2. The official start for the flexibility/deformability test starts with the S1 which is greater than 2.5mm of flex and then the S2 is greater than 5mm flex.
There are a lot of flexible adhesives on the market these days, if you are using an S1 or S2 rated adhesive you can have that extra piece of mind!
Have any classifications changed or been added recently does anybody know?
I think a lot of the time the classification is too broad
Bal SPF has always been my go to adhesive really which is a C2TE.
I'm now Moving to mapei and their two C2TE adhesives, the p9 and p10 both have different specs to each other and both different from bal spf.
I think this is mostly why the trade counters and a lot of fitters don't know the classifications because to a point they're irrelevant if there can be so much variation within them
Just checking in on this. Is everything still the same?
Grout classification isn't showing up on my end.
W= more resistant to water
A = better abrasion resistance
C & R are the same as adhesive properties. ..
The main question is . Is there a independent body that test adhesive to see Wether it is as good as the manufacturers claim .
Well my understanding if it has the EN 12004 stamp then it's been through those strict tests to get its rating.
Definitely wary of anything without a standard stamp.
I understand it was only the manufacture who did the test or had it done and then gave themselves the 'stamp'
I can't just throw some sand and cement in a bag and claim it to be in accordance with EN12004 C2TES2. That would be ridiculous
I know, but I believe that's how it works.
stand to be corrected.
Mark@Tilemaster would know
One thing that they could improve on is actually state the true result of a test. Not just is equal or greater than 0.5N/mm2. That way we could really compare products.
Some products may just scrap in where others well exceed.
Which are the most expensive do you find? (question to everybody reading this no matter what month or year)
united,
united,
