Three tiles have fell off, how do i refix them?
Go on then, I'll play with you for a bit longer.
If you're a "poor lady" why would you be spending what little money you have on primer, a grout float and the tube of Evostick when a small pot of fix and grout would have done the job? If you're that bothered about rot, dry or otherwise, you'd have done something about the bin bag draped over the windowsill that I assume is to stop water going behind the sink.
By the way, nice work peeling the flower sticker off of the tile. Gives it a real modern look.
Please can you tell me if the bin liner will have caused rot under the tiles on the windowsill. I've been worrying about it for days. I took it off now, it was there to keep windowsill edge dry from splashes.
I would really appreciate it if you could tell me why bin bag would cause rot.
Thank you kindly.
I'm really sorry to go on, it's just that timberwise are dry rot specialists who are accredited and they say on this page "This also occurs where large dimensioned timbers are in direct contact with damp masonry but remain well ventilated in which case the decay only develops within the interior of the member, the outer surface remaining sound." Dry Rot – The Facts from the Dry Rot Experts - https://www.timberwise.co.uk/2008/10/dry-rot-the-facts-from-the-dry-rot-experts/
There's also lots of other sites that say dry rot can develop where moisture is trapped without a chance to dry out, like my wet gypsum with an impervious tile on top, worried about the timber below the gypsum. Treating the outsides of the timber wont help, but thanks for the suggestion, as these sides are ventilated so I know they wont get dry rot but im worried about the side i cannot see.
How's the tiling going Graig...?
Learn't how to set a room out yet...?
You can always move the furniture about..... 🙂
(he's going to crack and brake cover soon, I can feel it)... 🙂
This is a pretty extreme solution, but then again you do seem to be allowing these 3 tiles to take over your life, so...
Hire an acrow prop, support the joist above wherever the offending bit of timber is, cut out the offending bit of timber and replace with new.
Is any of this at all necessary? No
Thanks for the suggestion but as the timber is in the roof void which does not belong me, I cannot touch it. Kitchen is mine as flat leasehold. I'm on top floor and flat in roof. It's an unusual set up as there is a stud partition wall between the kitchen and the roof void where the timbers are which lie being the gypsum plasterboard.
Time to lock this thread ?
please don't lock thread. I've appreciated the help on here, just got really worried about the trapped moisture behind the impervious tiles.
DIY Tiling Forum
female_novice,
female_novice,
