Herringbone Floor Tiling Set Out
you need to do a dry run across the room to avoid a double cut on your longest walls ..ie so you dont get small cuts on the end of your long cuts ..and the same length ways to avoid tiny cuts on your big v s as we call em hard to explain really but i used to do loads of hardwood floors as a lad
Thank you bud, setting it out wont be much of the problem although it will take time! I just needed a starting point now i know i need a 90 degree set "square"?? Lol
Uh huh! Hahaha
Now stop ya moaning and go practise setting out so u don't look like you're struggling on Saturday Ash! 😉
Only thing that is worrying me
Uh huh! Hahaha
its family so i can worry all i want after grouting up 😉
Where is the best and cheapest place to get one of these squares then guys? Can i use a 45 instead if the 90 at all because i already have one of those? Cheers
Which type Ash?
Do u mean u have a two sided 45o square? (Always thought that was a contradiction of terms!) 😀
Mr Tiler,
kevsalt,
Mr Tiler,
kevsalt,
