Herringbone Floor Tiling Set Out
Mr Tiler
hi guys, im finnishing a hallway on sat and will be measuring up for the living room, i would appreciate a few tips as ive been told its hard to set out thanks
90 degree herringbone is easy.... true herringbone 45 degrees is a pain.......I started a thread on this about a month ago....
Have only ever done it once, don't find that there's much call for it.
you need to do a dry run across the room to avoid a double cut on your longest walls ..ie so you dont get small cuts on the end of your long cuts ..and the same length ways to avoid tiny cuts on your big v s as we call em hard to explain really but i used to do loads of hardwood floors as a lad
Thank you bud, setting it out wont be much of the problem although it will take time! I just needed a starting point now i know i need a 90 degree set "square"?? Lol
Uh huh! Hahaha
Now stop ya moaning and go practise setting out so u don't look like you're struggling on Saturday Ash! 😉
Only thing that is worrying me
Uh huh! Hahaha
its family so i can worry all i want after grouting up 😉
Where is the best and cheapest place to get one of these squares then guys? Can i use a 45 instead if the 90 at all because i already have one of those? Cheers
Which type Ash?
Do u mean u have a two sided 45o square? (Always thought that was a contradiction of terms!) 😀
One sides 450 i think the other side is 300 but i would imagine i can get the same result using it what you think 3?
Mr Tiler,
kevsalt,
Mr Tiler,
kevsalt,
