Dust and eye protection masks
Wishiwasatoptiler
Hi
Looking to pick up a few masks for a crappy ceiling pull down job. Looked at these. Any one used them. Are they any good
Would then use for tiling use. Cutting boards, grinding floors etc.
Not sure how well that would seal to the face, also I think p3 is needed for us not p2
I use that jsp force 8 but it’s getting a bit tired now, taking it on and off all day isn’t ideal. Do you use them for 1 day impish then throw them away? Would you trust that for heavy dust ?
No, just nuisance dust. They aren't the easiest to breathe in for a length of time. Good for a quick dry cut, or mix though.
I bought an M rated vac recently so that sucks up most dust from everything now.
THe main hazard for us daily is mixing adhesive and grinding porcelain, even with a sponge on the grinder it’s still air bourne. If you mix adhesive on a sunny day with no wind you can see the cloud and it’s pretty immense
Wishiwasatoptiler,
Filip,
Wishiwasatoptiler,
Filip,
