Current concerns with my new tiling. Am I right to be concerned?
Dirtypool
Hi I'm Dp and I'm looking for perspectives on my new tiling. Im concerned with tiles not having crisp or accurate cuts so tiles don't have uniform grout lines. The tiles pictured are set on new plasterboard so walls are straight.
Should I be right to expect a better finish with cut tiles being cleanly cut. All tiles being spaced accurately and thus uniform grout lines or is my expectation too high. Should grout be better finished at corners? On the windowsill where my finger is how the heck would water run off the windowsill past that lip?
Thanks in advance for any help.
Dp IMG-20180625-WA0020.jpeg IMG-20180625-WA0018.jpeg IMG-20180625-WA0016.jpeg IMG-20180625-WA0014.jpeg IMG-20180625-WA0012.jpeg IMG-20180625-WA0010.jpeg
First thing just cos walls are new plaster board doesn't mean they are straight ,but this should be sorted out before tiling starts .
That said Cutting of tiles is very poor ,short and left with rough edges joint alignment in the photo is poor too.
Has the grouting only just been finished? As this looks like it's very shady too.
All in all a fairly poor job
Thanks for the reply. Yes grouting just done today and some yesterday. I've raised my concerns with the contractor. Do you have any other advice for me? What should I do if he doesn't fix. How does the grout look shady to you?
Not sure why anyone thinks that dark joints enhance any tile!
It may lighten up as it dries over a couple of days but it’s still going to be a poor job.
Everything you mentioned is wrong and it’s now that you have to get it altered.
There should be no reason for fixing tiles with those cut edges.
Thank you. I'm going to try with him tomorrow morning and see if he has the appetite and capability to fix it. To be honest the whole room is similar.
I like the dark joints.. but then id still be on here with the same concerns with white grout I suspect
It's not the thickness it's the overall dimensions. Tiles 2-3mm ( or more..) different in width and length makes a tight, constant grout gap impossible. Contrasting grout only amplifies the problem, not that I'm trying to condone the finish you have.
Whan you look at a misaligned joint look at each tile . For instance if the tops of the tiles are level and the bottoms are not you can see that they are different sizes . But that doesn't get away from the other issues .
Thanks and noted. I've been through it with him and he is addressing most of the problems. He is correcting cuts as I write.
Yes thanks. I have done that and yes there are variances in tile size so I won't push him where that's the case
Thanks and noted. I'm going to be a regular buyer of tiles where do you suggest as a better alternative to source tiles from?
In Manchester?
I'd try TilesUK, Montford St, Salford or CTD at Denton.
If you want something really special (and have a good budget) - Casa Ceramica.
(DO NOT go to Better Bathrooms!)
Porcelenosa aren't that good . Their black polished porcelain used to be chocolate brown. Their glaze is known for crazing along the score line when cutting and you also pay a premium for using their products . There are better tiles available for less money . I do a few of their tiles as a bathroom showroom in associated with sell their products and i dont find them all that.
I can go to a CTD in any part of the country and buy materials for the same price as my Newcastle branch!
I’am sure we’ve all had poor quality tiles from somewhere and we have to deal with it - but once you’ve fixed them that’s it - no more complaining.
Dirtypool,
Time's Ran Out,
Dirtypool,
Time's Ran Out,
