Concrete panels on bathroom walls?
Jonathanb
Hi, my first post on here. I am looking at fitting thin concrete panels on my bathroom and shower wall. Has any one used them before?
The ones I was looking at are either Concreate or https://livingconcrete.co.uk/concrete-panels
The livingconcrete type say you can use them on a wall by fixing with tile adhesive but not much more imformation.
The Concreate say they need to be glued to the wall, but does not mention if they can be fitted with tile adhesive, spacers and grout.
P.s I’m not a tiler, I’m a carpenter
Cheers
John.
I do a lot of research for everything I do in the the house :grinning: You should of seen the amount of samples I had for the dining room floor (not tiles)
Saying that the research sometimes saves me a fortune. All the bathroom ceramics etc I got for half the price of U.K. suppliers. Ordered it all from Germany.
John,..
Sorry, it’s a Mafell MT55, a better version of the Festool ts55 :smiley:
Cheers
John..
Yes I know it 🙂 nice!
No! 😛
Well in my experience they’re just not up to it, and in truth if you want a pristine cut, which I’m guessing you probably would, then it has to be a wet cut.
Sounds dangerous but nearly everyone I know in the large format game uses an angle grinder and a wet sponge held at the back of the blade.
Confirms to HSE, probably not! 😀
But it does work and helps a great deal with dust suppression.
I spend a huge amount of time mitring thin tile, and cuts have to be perfect, as I’m sure you’ll understand.
Yes there is machinery available that can do it for you, but it comes at a price and is very specialised.
Thin tile work is different from regular Tiling, at a risk of getting this comparison wrong, a bit like carpentry against cabinet making.
The same, but different.
If you are that intent on perfect cuts I’d suggest buying a 1200mm mechanical cutter, using it and selling it on.
If you consider something like a sigma 3e4m, yes a big outlay, but you won’t loose more than £100 if you keep it in good condition. You’ll sell it in an instant at that price. Highly sort after second hand.
Then if you have L cuts, you could consider waterjet cutting them all at once.
Hassle yes, perfect? absolutely.
It depends on the level of finish you want to achieve.
Even we get certain pieces waterjet cut.
This is what I do on a day to day basis.
C4F1BEDB-56A9-4A5F-807C-61A4068B4C7D.jpeg B5B0103A-F557-488A-A095-3CF2D40C82BE.jpeg
Cheers for that, I will look into a 1200mm tile cutter. I think my local CTD hire them out.
The angle grinder I can borrow of one of the lads I work with. Luckily my bathroom will be nearly all straight cuts, nothing complicated.
It might work out easier for me if I do get the Porcel-thin tiles as I can hopefully use a glass cutter, straight edge and a angle grinder.
John..
Call me old fashioned but seems like a lot of faff for something you can't even use in a high water zone, you could have tiled it by now 😉
There was only 2 company’s I could find that supplied the concrete panels. One sent samples but said they can’t be used in wet areas. The other company said there’s can, but didn’t bother sending samples🙁
I can’t start tiling yet as I’m still waiting for the vanity unit to arrive, then hopefully I will have samples for the Porcel-thin tiles.
John..
Still be a bit lighter than humping around 3m kitchen worktops all day, or climbing around scaffold with a 4.8m length of 200x50 timber on my shoulder 😀
John...
Let’s see if you say the same thing once you’ve troweled adhesive on the back and you’re lifting them above shoulder height! 😀
The wife is making the decision this morning
John.
Kool🙂
Is she going to fit them too? 😀
If you can manage a day off before you fit them and travel down to Rays for the day he’ll happily give you a day’s training on fitting them f.o.c.
And the best bit of advice I can give you is that do whatever it takes to make all your substrates as perfectly flat as you can.
Go above and beyond what you would class
as ‘good enough’
If you can achieve + or - 1mm on all surfaces to be tiled, your job will be simplified 10 fold.
And make sure you buy spare pieces, the likelihood is that you will need them.
If it’s a stock item, you can normally make an attangement to return unused pieces, but if you don’t ask, you won’t get. 🙂
I would love to go on the training course, but it’s around 250 miles away from me.
Getting the walls flat shouldn’t be a problem. I’m pulling the bathroom to bits. New stud work and the external wall I’m taking back to brick.
The only walls I will leave are about 600mm wide paramount wall, so should be flat.
I’m going to order a few extra, hopefully I won’t need them.
One question, what size tile trim to use? 6mm
Cheers
John
Cheers
John
Trim 😱
How many concrete walls do you see with metal trim? 😛
Select my avatar (pic), top left of rhis post, and when pop up appears select albums page.
First two albums demonstrate thin tile mitring.
Just looked at your pics, looks excellent but there’s no chance I’m trying that😀 . First attempt and trying to mitre around my window reveals.. 😱..
I wasn’t going to get chrome trims, I was looking at the Schluter trims in one of the grey colours.
John
Bathroom Tiling Advice
Unsolved
Jonathanb,
Jonathanb,
Jonathanb,
Jonathanb,
