Seeking advice on an ongoing job (bevelled metro tiles)
Tom Ewer
Hello,
We’re on the home straight of our new kitchen being fitted, and the fitter has been working on the tiles.
He originally said that he’d mitre the tiles (here’s what we’ve got) to provide a clean finish, which sounded great. However, when he tried to mitre them he couldn’t get a good enough finish on the edge.
His next idea was to use a 9mm trim, and file off and grout the corners (i.e. where separate pieces of trim met). That sounded awful to me, but he said it would look good. In short, it didn’t (and he agreed).
His next idea was to use corner pieces (like this, but plastic) to finish off the corners, which I agreed to. However, he then decided to switch to a 9.5mm trim (without first telling me) because he felt the 9mm trim was too small, and took delivery of and fitted l-shaped corner pieces (rather than the style I agreed to). I've attached the end result.
I’m really unhappy with the finish. I think the trim looks too fat and takes over the tiles, and the corner pieces look really budget. Ideally I would’ve loved to have seen a mitred finish (as we were originally promised), but if not that, a much ‘cleaner’ finish with the trim.
My question is this: can we rescue this? Could the tiles be mitred (and our chap just doesn’t have the knowhow to do the job right), or if not, is there another approach (with or without trim) that would look better than what we’ve got?
I’d appreciate your thoughts!
With the right tools patience and know how I think any tile could be mitred you can cut out the trim with a Stanley knife and glue new stuff that has backing cut of it (if plastic) I can see on the left of the picture the boxing is not brickbond I think would look better if it was
Thanks for the replies!
With regards to the brick bond, are you saying that the front of the pillar should look the same as the right side of the windowsill that you can see to the right of the photo?
So if I'm interpreting that photo correctly, the width of each tile should be consistent even as they 'wrap' around corners, if that makes sense?
Sometimes that will not be possible because of cuts but as close to as possible at least not starting a full next to a half but a third next to half instead of that makes sense
Yes.....you should follow the pattern round the whole room to keep the brick effect.
Your tiler has gone from landscape to brick bond, the face of the boxing in should have a join in it not just full tiles.
If you look at the internals of your window there's no reason why the boxing shouldn't be the same
I always trim the top, it's an exposed edge and you can see the ginger biscuit If not
But if you use 8mm there will be a 2mm lip .
Not saying your wrong or right, as all ways it's a personal choice my customer gets to choose and if they want trim at the top.....no problem.
BTW most metros I've used are white biscuit...😉
How would you finish off the top if you don't use trim? I'm thinking in particular of the hollow top end of trim running up a corner.
Mitred for me. They're soft and easy to work. It's worth the effort unless it's a new-build site job. It looks a bit "Bish bash bosh" with all that trim!
apart from the boxing in which doesnt look terrible . the rest of the job looks decent , i use trim on the metros, usually 8 mm
Some
Metros are white back but some are biscuit with a thick glaze on, there's that many different ones now you never know. Some are really heavily bevelled and some hardly at all.
I'll try and dig out pics from a job I did with mitred crackle-glaze efforts from Laura Ashley.
Terrible to work with as the glaze kept pinging off!
I've used them too imp, all The laura Ashley tiles I've used haven't been great, I suspect there bct
Tom - not sure where to begin with this.
The trim is wrong, the boxing is wrong , the setting out of the cuts is wrong.
Everything others have said!
For me they should be mitred, the tiles should be laid like bricks so on a return of a full face it should be a half tile and on the cill the front and top should be the same - a brick. Most do this type of tile like wallpaper and I prefer brick blocks. Just my choice.
Tom Ewer,
Blunt Tool,
Tom Ewer,
Blunt Tool,
