Seeking advice on an ongoing job (bevelled metro tiles)
Tom Ewer
Hello,
We’re on the home straight of our new kitchen being fitted, and the fitter has been working on the tiles.
He originally said that he’d mitre the tiles (here’s what we’ve got) to provide a clean finish, which sounded great. However, when he tried to mitre them he couldn’t get a good enough finish on the edge.
His next idea was to use a 9mm trim, and file off and grout the corners (i.e. where separate pieces of trim met). That sounded awful to me, but he said it would look good. In short, it didn’t (and he agreed).
His next idea was to use corner pieces (like this, but plastic) to finish off the corners, which I agreed to. However, he then decided to switch to a 9.5mm trim (without first telling me) because he felt the 9mm trim was too small, and took delivery of and fitted l-shaped corner pieces (rather than the style I agreed to). I've attached the end result.
I’m really unhappy with the finish. I think the trim looks too fat and takes over the tiles, and the corner pieces look really budget. Ideally I would’ve loved to have seen a mitred finish (as we were originally promised), but if not that, a much ‘cleaner’ finish with the trim.
My question is this: can we rescue this? Could the tiles be mitred (and our chap just doesn’t have the knowhow to do the job right), or if not, is there another approach (with or without trim) that would look better than what we’ve got?
I’d appreciate your thoughts!
With the right tools patience and know how I think any tile could be mitred you can cut out the trim with a Stanley knife and glue new stuff that has backing cut of it (if plastic) I can see on the left of the picture the boxing is not brickbond I think would look better if it was
Thanks for the replies!
With regards to the brick bond, are you saying that the front of the pillar should look the same as the right side of the windowsill that you can see to the right of the photo?
So if I'm interpreting that photo correctly, the width of each tile should be consistent even as they 'wrap' around corners, if that makes sense?
Sometimes that will not be possible because of cuts but as close to as possible at least not starting a full next to a half but a third next to half instead of that makes sense
Tom Ewer,
Blunt Tool,
Tom Ewer,
Blunt Tool,
