Retro fit ufh & Hydrogen gas causes floor failure.
In the case of using the Isolastic liquid, does it bind the alkali element of the Portland Alan, how does it work?
Mapei also state that latex plus is a no no,
reading tech sheets there's little or no difference in the two products, but I'm sure there must be something.
Would just like to understand how this can be prevented.
Not sure it binds the alkali element but some latex compounds have resistance to alkaline conditions. Styrene butadiene is used to make latex concretes which have high flexural strength. I don't know what the mapei stuff is made from so not sure. I know it's a type of latex so maybe it's the butaduene form.
Thanks Alan.
I will call Mapei again, but don't hold out much hope of finding out the why's and the wherefore'a, I'm sure I'll just be told 'it just does!' Haha
Thanks again
Bitumen would work yes but a nightmare to apply. I think mma would work as well but would be fearfully expensive and fiddly to work with. Never tried SBR but as that can suffer from alkali burn I suspect that won't work. Acrylic doesn't work. PVA works in large quantities but can take an age to dry and set. Epoxy would probably work but again would be fiddly and costly. A polythene membrane is best for screeds.
Would you have any guess as to why they say prime and grip works?
You say acrylic doesn't work, and I believe you,
Look at this.
Tried comparing Isolastic with latex plus and struggled to find a difference here too. PH values almost identical.
???? Who done that then
I thought you pretty much said cement or anhydrate it going to fail and that priming as a blanker isnt that good . So if you said that I stand by what I say if I misunderstood you tell me .
I thought you pretty much said cement or anhydrate it going to fail and that priming as a blanker is that good . So if you said that I stand by what I say if I misunderstood you tell me .
No I misunderstood your post. Who has bought products to market without testing?
I'm afraid not. I don't know why they say a lot of things sometimes. Also to be fair I don't know what it's made of. I suppose it's possibly a numbers game. Put enough if anything on and it'll work. The amount youd need though is just impractical. If it's an acrylic it's a risk.
Agreed.
So your saying they tested it but it's still going to fail
I hope you've quoted the wrong post! 😛
Everything Alan has said I agree with, I've researched this to death over the last week and I have found nothing that would make me conclude a different outcome to what has been said.
He didn't say it was going to fail, he said he didn't know the chemical composition of prime and grip and therefore couldn't comment.
And what he said about acrylic primer not being reliable, is also true.
I've read that myself in the concrete journal.
The only ones that can answer that are Mapei, that don't mean they'll tell me tho.
This is a low end product with a very highly strung installation technique.
Appears to be have been devolved with another market in mind originally, and they've tried to adapt it for tiling.
If you pick a hundred tilers that are not on a forum, how many do you think will have a successful install with this product?
How many will even bother with the installation manual?
This stuff is an accident waiting to happen.
But that's only MY opinion.
Alan has practical experience, and that's why I was hoping he may of been able to answer my questions.
we all know in the real world, that experience far exceeds the knowledge gained from reading alone.
that's what I'm getting at. Who is supposed to have tested what?? which manufacturers and which products?? don't get me wrong I'm not having a go or trying to pick an argument. Just trying to work out what you are actually asking/saying
Sorry I just don't get it . I thought you saying with your chemistry knowledge that even following their recommendations it was still going produce gas and ultimately fail . I therefore misunderstood what you were saying .
WOW!... Great post.. But trust me .. I will be giving these situations ( jobs) a wide berth..jeeees..what is happening to our lovely trade!!
So much prefer the old days... ( coming from an old fart)!!lol..
You guys that deal with these specialised jobs should most definitely charge more.. IMPO..🙂
This product is liquid,we use just for fit ditra-mat,is like the glue for vinilin.
Looks like we have a winner. Can't see any reason that would not stick. Not sure a primer would be needed but I'd be guided by Ardex on that
Old Mod,
Simons70,
Old Mod,
Simons70,
