From this page you can select the type of silicon you require and then add to basket and and go to checkout. Simples.
Coloured mastic sealants - Sealants Online
I'm definitely missing something here.From this page you can select the type of silicon you require and then add to basket and and go to checkout. Simples.
Your to quickMy mistake select your colour and how many from this page
Otto-Chemie OTTOSEAL® S100 Premium Bathroom (Internal) Silicon Sealant - Multi-Purpose sealants - Product List - Sealants Online
75 different colours here, including the one you need
Otto-Chemie OTTOSEAL® S100 Premium Bathroom (Internal) Silicon Sealant - Otto-Chemie Mastic Sealants Adhesives & Tools - Product List - Sealants Online
No but think I may start.Do you use them Julian?
I know there a good make and do ones suitable for stone.
Normally have to order the stone ones from CTD, expensive and poor colour choice from mapei.
You?
I'll give them ago then, thanksLoads of choice for stone as you say, they've never failed me on delivery either, normally get them sent to the job I'm working on. I generally bring an off-cut of tile home and match it to the colour on screen and they are always spot on
That's a great website John, many thanks for that.My mistake select your colour and how many from this page
Haha who pulled your chain Craig!
I'm not saying u CAN'T grout ur corners!
U do what u want to!!
You're a grown up!
I'm saying u SHOULDN'T and I've given my reasons, why else would u Silicon dry corners?
It's not for the fun of siliconing is it!
And I'm not gonna call the Silicon police if u don't Craig, it's ok! 🙄
I do like a friendly debate with all the elitists though, it makes my weeks sometimes 🙂
Does this no grout apply between ceiling and walls or is it just in between tiles ?
The thread needs finding where someone askedwho grouted corners before they siliconed , i think @Bri made it, im sure it was 50/50.
No one has pulled my chain marc , hence the smily faces 😉
I just don't see the problem ,if a wall is going to move that much , Silicon will not stop opening up .
I do if the chosen grout is anything other than white.I always run a bead of decorators caulk around ceiling so it can be painted and you get a nice sharp line around the ceiling
Mmmmm i do remember a thread on it, could of been on the other forum, my memory is not my greatest asset 😉I don't remember doing a thread about Silicon/grout in corners, I've definitely stated that I don't Silicon up to ceilings skirting so or architraves. I'm like you mate, I do what I believe to be right on the job I'm on, I am a bit of a stickler for Silicon only in corners but, never in my life have I siliconed to a skirting board (unless it's a tiled skirting) or used anything other than grout up to ceilings. I do Silicon around window reveals and I know a lot don't.
@3fall ofcoarse im calling you elitist
Im joking mate, im just on the wind up, i was hoping a few more elitists would of bit really![]()
Hahaha I just like watching u rant Craig! HahahaI take it these are the bathrooms that are failing marc ?
Bad floors, bad prep bad walls bad prep all in all a crap job.
I can show you hundreds of shower rooms , mine included , which is used 3/4 times a day for nigh on ten years, no leaks apart from the crap shower screen.
I can show you showers ive never tanked which are fine, mine included , i can show you pebbledashing/rendering which i used loads of pva on which are solid after 30 years , no cracks no blow offs, i can show you women i have slept with who .... Hang on, off topic 😉
All im saying is if its prepped right and the job is done right some things are just over kill
Ps you can say i told you so all you want, mine aint failed , ever my man, and ive filled ever corner ive ever tiled 🙂
Yes all true.I think also it depends on the Silicon being used. Bath and Sanitary is what's needed, but I know for a fact some plumbers use the cheap general purpose Silicon which does not adhere to the tiles - maybe that's what was used in your pics Marc who knows
