Dash J
I have never not cut porcelain dry
Only ones I struggled with had a glass face
Discuss Struggling to cut porcelain tiles with Sigma 3D2 in the Australia area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
and if that does not work you can try driving over your rubi or smack it against a wall or use a flame thrower or just do the right thing and throw it off a cliff :smilewinkgrin:Don't have all that faff with a Rubi!
Just scribe and hit it with a hammer.
Just to add , make sure you set handle depth to suit tile depth , this makes full use of the breaker ... 5mm from rail to handle runner.. Then score nd put breaker foot about an inch in and sharp quick wack on the handle to shock the tile and if you have set the depth correctly , then no chance of crushing the tile no matter how hard you hit the handle.
a common mistake is not setting the cutter to suit tile thickness , a big advantage of the sigma over any other machine.
Thanks @Dave for this original advice and to anyone else who can just give a wee bit more clarification on this adjustmentJust to add , make sure you set handle depth to suit tile depth , this makes full use of the breaker ... 5mm from rail to handle runner.. Then score nd put breaker foot about an inch in and sharp quick wack on the handle to shock the tile and if you have set the depth correctly , then no chance of crushing the tile no matter how hard you hit the handle.
Reply to Struggling to cut porcelain tiles with Sigma 3D2 in the Australia area at TilersForums.com
