Nero Granite - The Swiss Quality Tile
R
robbieraven
Hi Guys,
Just been to to spec out a job and the customer has bought these ready to go, have to confess, never come across them before, they seem to have a veneer of what looks like granite effect porcelain on the faces and then a backing of something that neither resembles ceramic or porcelain but looks almost like a manufactured cementous material. Anything to know about fitting these and how they cut with a wet cutter?
Cheers Rob
Hi Rob,
I've used Niro Granite tile previously,The "Traces" range from TG and found them to be of good quality.
Never had any probs with cutting manual or wet."Traces" are a glazed porcelain tile,However the
discription you have listed may be a different range.Does the veneer look like the lines of a finger
print ?
Thanks all, Ian yes I haven't got a sample, tried to find them online, this was definitely the site Niro Ceramic Group but I couldn't find the granite tile they had bought.
Cheers Rob
Hi Rob,
print ?
Hi, I found this post from years ago. I have some of these tiles with the lines like a finger print and can't find any to match, would you know where I could source some for the adjoining room?
Hi Rob,
print ?
Hi Ian,
I found this post from years ago. Do you know where I could get these exact tiles Traces range made by Niro Granite with the finger print like design from. I need to lay in an adjoining room or pull it all up.
robbieraven,
benbit,
robbieraven,
benbit,
