Tiling Job gone wrong?
We cannot tell by the pic as to what is happening underneath,,..
If you think there is a problem or a leak occurs then it has to be investigated.
Appalling workmanship, that shower area is atrocious.
Your drain looks high too, you need a professional tiler to come in there to look at it.
With so many good men slack with work there is no excuse for this sort of work.
Its just a mess!!!
There has been no care taken with the trim, god knows whats going on with the floor but it is astatically bad and could be failing. Have the corners been grouted or siliconed?? Looks like grout to me!!
Overall, not much pride in this work. I would also advise against regrouting with lighter grout colour as I think this could possibly show up more problems that may not be apparent just now like lipping.
£592 doesn"t sound enough to fit the tray and complete all of the tiling works to me ,i think the tiler realised this so he subbed the work to a novice who was happy to do it cheap to gain experience.The result? A catalogue of errors that are frankly laughable.
The tray was fitted by the plumber - all the £592 was supposed to be for was tiling and tanking of a total of 15.5sqm of wall and 1.5 sqm of floor.
The tiler came yesterday to fit in the drain cover - why he couldn't do it in the first place, I really don't know. He's siliconed the surrounding and grouted it. However, the creaks are still there. I've filmed it and put it on youtube:-
YouTube - Shower tray creak.MOV
Listen to the sounds and let me know what you all think please!
doesn't sound the best does the base move when you walk on it and does it separate from wall tiles
No - I don't see the base moving but I shall check it with a magnifying glass tonight to see if it is seperating from the wall tiles.
That sounds like the waste pipe expanding and rubbing up against wood. Does it make a noise a little while after the shower is running or straight away?.Also how far does the waste pipe go before it reaches the soil stack?.
It only creaks if we stepped on the tiles between the drain hole and the wall. No creaks are evident when we step anywhere else in the shower tray.
I have found even more shoody work and here are additional photos I took this morning - what do you think of the Silicon sealant on the shower tray and wall? Does it look like there are air bubbles - bits coming off loose?
not a good job at all mate,get them back to sort it,or if you want rid,pay him or don't,and get someone right to sort it,
has it not started leaking through the ceiling yet,the drain looks all wrong to me,i did one the other month,the drain sleeve should be flush with the tiles and then the cap placed/screwed on top so the water flows on the cap and down the drain:thumbsup:
Basically the guy who quoted the job should of suggested a corner piece for your tile trim with so many years alleged experiance it's a given to notice these things. No excuse for the grout other than blatant disregard for you! As for the price I'd get another Tiler to quote you for rectifying the problems and show this to your cowboy, and tell him this is the reason I will not be paying you!
Does anyone who has given advice above know whether the finishing complies with BS5385 fitting standrads please?
This is what the tiler is insisting in his response to my counterclaim
BS5385 leaves a lot of scope for poor work I am afraid - for instance it allows a 1mm deviation in levels when using a 2mm spacer - a veritable door step when dealing with rectified tiles!
2mm is the minimum recommended joint, although I almost always use 1mm quite well when using porcelanosa's rectified tiles.
Must admit, I check the suitability of tiles and walls very carefully beforehand though.
People need to remember BS5385 is guidance - not law.
If you want to counter their insistance that it's all "within acceptable standards and tolerances", I'd suggest you take a tile off the wall.
If you tap them, do they sound hollow? With such poor workmanship it's likely they spot-fixed. A complete No-No.
Don't pay until you're satisfied, and in future always insist on written quotes outling EVERY detail.
Just a thought regarding your grout colour. Do a search for Aquamix colorant. It's a liquid that will colour & seal any grout. It turns dark grouts to light grouts. It comes in many colours. You can apply the solution yourself with a toothbrush. However, you just first remove the sealer that the builder applied. Again, there are products on the market that will clean & remove sealers. It might make you feel a little bit better about your bathroom. Good luck. Sean
wildfirejc,
Sean Kelly,
wildfirejc,
Sean Kelly,
