tiler robbo
Hi guys,
I'm about to start tiling the monster-in-laws bathroom & was after input from you guys, the experts, before I start. Walls are 2.4 high by 2.2 x 2 & 1.7 x 2. Tiles are 45cm x 31.6cm & was going to lay horizontaly in straight lines (not a brick work pattern).
Question 1:
The window is not quite centered, out by about 15cm to the left, was going to chose to start from the centre of the wall so even cuts at each end but will it look odd being tiles are not quite centre to the window & the tiles cut each side of the window frame will not be exactly the same?
Question 2:
When battoning up, if I start at bath level, it will leave me a nice even cut top & bottom. Do I need to start the batton a tile run down from the bath or can I use the bath as a start point with the batton running on? My mate has fitted the bathroom suite & suggested I use the bath to start as level but I read somewhere it's not a good idea as the tiles may slip?
No doubt there will be more questions to come with things I've forgotton about but any advice to start is much appriciated.
Will post pics of before & after for feedback, cheers, Robbo
Question 1:
Question 2:
