tiling up to carpet
C
curlycan
Hi guys I have a flooring job to start on monday and i'm after your ideas on how you separate tiles from carpet at the door jam. I don't know if there will be a height difference ( I shouldn't think there will be much if at all), Tiles will need cutting at door jam so I would think some kind of trim would be best. All ideas and recommendations greatfully accepted thanks.
You answered your own question, yes a tile to carpet trim, found just about everywhere :thumbsup:
Don't buy the trim that is raised and you have tonknock down to the height of the tiles with a rubber mallet once the tiles are laid. The sales rep told me they just needed to be tapped down slightly, however they had to be hit a fair old whack and I ended up chipping a tile, had to dig the grout out, pop the tile and relay and regrout. I now use the ones that come in 2 parts, you lay the base and tile up ton it then the top just clips over the top with barbed like brackets to hold it in place, easy peasy.
Varley, it's a mad idea to start bashing down a metal bar over your newly laid tiles. I chipped a 600x600 tile last year whilst bashing down the door trim. All that extra cutting and grouting, and not to mention all that extra addy. These trims cost £10. I try not to use them if I can. Cheers Sean
Curly, can you get Schluter trims? They are what I use when transistioning from tile to carpet.
Schluter has a lot of choices for colors, finishes, profiles, etc.
Hello Marty mate.. hows tricks me old mucker..
Welcome back Mart. How the hell are you? Where have you been all this time mate?
tiling up to carpet
curlycan,
curlycan,
