Discuss This Weber Adhesive Is Brilliant!! in the Australia Tiling Forum area at TilersForums.com.
57
473
Surrey
This Weber adhesive is brilliant - you don't even need to clean your bucket out! :p:p
I've used it before, weber.set white, the standard set one in the blue bag - used some yesterday and when I wanted to mix a new batch I scraped the bucket out and put the scrapings in the skip, as the day went on I suddenly realised that I hadn't noticed it picking up in the bucket at all - so I went to the skip and checked the first lot I had scraped out - still just as it was when I mixed it! Checked it again when I finished for the day, still the same but with a slight skin which I expect the wind had done.
So, this morning when I arrived for work the first thing I did was go to the skip and check it again - skin a bit thicker but under that it was still soft - so much so that I could have stirred it up and carried on using it!!
Fortunately the tiles I fixed with it were ok and the stuff on the wall had hardened - ain't done over much for my confidence in the product though tbh.
Reply to This Weber Adhesive Is Brilliant!! in the Australia Tiling Forum area at TilersForums.com
