Self-leveling compound **ON TOP** of Marmox boards
L
Latipanu
Hello
I am new to the forum and would appreciate some expert advice.
The question is: Is there some kind of self-leveling compound that can be used ON TOP of Marmox boards.
Having just knocked down a dividing wall, I find that one floor (already insulated with Marmox) is LOWER than the other side.
I need to add between 2.5 and 4 cm to the Marmox side to sort out the problem.
Ideally, I would like to embed heating mats above the Marmox, so I wonder if there is a product that could be used quite liberally to embed the heating mats **and** sort out the floor level problem.
Advice on product types, even specific brand names, would be much appreciated.
Many thanks!
DB
Thanks, Andy
Is there a minimum thickness to ago with the 50 mm maximum? I'm aiming to blend out the difference in height.
Really appreciate your advice and the quick response!
Cheers
DB
Weber floor flex.....it is flexible can be used on top of marmox boards and ufh and can go to a depth of 50mm...:thumbsup:
Fit a heat mat & then self level over the top of the wires then tile.
Weber floor flex is good but if you can get it I would opt for Mapei renovation screed as it flows nicer & finds it's level easier.
I always use 'Weber floor flex' or 'Ultra level it one' both easy to work with and both go to 50mm in one hit.................. Just out of interest Ultra now do one that can go to 75mm in one hit :yikes:
Hi Andy
Thank you for your reply. Is there a MINIMUM thickness to go with the 50 mm thickness?
Really appreciate the fact that you took the time to reply.
Cheers
DB
Thank you, Stef
I've been doing some measurements, and I think the difference in floor level is about 2.5 cm. Googled the Mapei product and it goes up to 30 mm.
Would the Mapei product be suitable for embedding the heat mat *AND* making good the difference in floor levels?
Cheers
Thanks for your advice. Very much appreciated!
Have you ever applied either of these products on top of Marmox boards? My concern is that the self-level compound might not hold in the thinner areas (as I try to blend out the difference in floor levels).
Better to apply a minimum of, say, 10 mm in the "high" areas and then build up to 30 mm, or can I apply zero on the high areas, and then just let the compound do its magic?
A novice's question, I know.
Cheers
DB
I just noticed that you wrote 2.5-4cm, I thought it was mm, sorry.
You could add another layer of Marmox on top of the existing boards, just make sure they are glued & screwed with appropriate washers.
Weber floor flex is minimum 10mm over wooden substrate.
Renovation screed goes down to 3mm.
Latipanu,
TJ Smiler,
Latipanu,
TJ Smiler,
