No More Ply and Wedi Alternatives
C
Chris Churchill
Hey all,
So I'm about to start working on a wetroom project on my first floor (and am not interested in UFH). Naturally, this is currently timber floorboards - which are in good nick, however, in a previous thread, someone posted that I should remove these and place 22mm NMP down directly onto the joists instead of using standard ply. This is fine - as I want to minimize the raising height for when I tile to keep them inline with the next room. Once laid, the plan is for me to Ditra over the top of this (which I already have).
The problem I have, is that NMP is pretty scarce in my area and even finding it online is proving troublesome. Therefore, can anyone suggest any alternatives? I'm in the South East (London/Kent borders) so can collect relatively locally.
I have found this:
Heavy Duty Construction Board 22mm | Topps Tiles - https://www.toppstiles.co.uk/tprod46967/heavy-duty-construction-board-22mm.html?utm_source=google-shopping&gclid=CjwKCAjw8_nXBRAiEiwAXWe2yZtG2Wtu3dMJtVOaPGy7GyNZE8oRo-DNPMAYOwAebSXx182_umi1oRoC0JQQAvD_BwE&gclsrc=aw.ds#fo_c=2258&fo_k=8c8857a8bf5780176a203808fa236ff2&fo_s=gplauk
However, anything Topps immediately feels like a rip.
Additionally, as I'm looking to do a wetroom, I'm having the same issue regarding backboards for the wall. Wedi boards have been suggested, but again can't find them anywhere. Also, Kerdi boards agreed are nice, but WAY out of my budget.
B&Q do these:
Aquadry Waterproof Board (L)1200mm (W)600mm (T)12mm | Departments | DIY at B&Q - https://www.diy.com/departments/aquadry-waterproof-board-l-1200mm-w-600mm-t-12mm/259514_BQ.prd
and I've also found these:
Marmox: Marmox Multiboard - https://www.tilefixdirect.com/product/Marmox-Multiboard-Tile-Backer-Insulation-Boards
Orbry: Orbry Board - https://www.tilefixdirect.com/product/Orbry-Insulated-Backer-Board
Can anyone point me in the right direction for each of these products or suggest any alternatives - and also back them up with reasons?
Many thanks!
P.S I should also note that these boards have to navigate around a labyrinth of steps which I'd be doing on my todd. I'm no Schwarzenegger, so dare say, weight and the odd wedging does play a slight factor. I'm also open to WBP Ply too with good reasoning as I'm Ditra-ing over the top, but either way, floorboards are going.
Leave the floor boards if there in good order your just making more work for your self. Fit the tray as per instructions which will probably leave 10mm at a guess for your overboarding. Over board the floorboards with 10mm marmox board, board your walls with marmox board and seal all up. No need for ditra, you don’t need to use it just because you have it. Why no ufh to help dry it out?
Thanks for the reply, however my research indicates that Ditra is the superior product - especially for wetrooms so sorry to say I think I'm still heading in that direction. Also, I cant justify buying an alternate waterproofing for the floor when I already have this in place. The question I have really is around the substrate to accommodate for the Schluter before I tile and where to get it from.
Also, with regards to overboarding the floorboards, I wanted to remove any form of lateral movement or bounce as suggested in my original post (Ditra 25 and Kerdi Keba for floor, walls and wetroom? - https://www.tilersforums.com/threads/ditra-25-and-kerdi-keba-for-floor-walls-and-wetroom.86017/) and not increase the height. Understood that overboarding will assist with this movement, but from what I understand, not completely. Additionally, many threads around this topic (on this forum and in several other places) suggest to remove the floorboards if you can - which I can, so I am.
Finally, the underfloor heating is just not in my budget. We have rads in place and don't see the need to add additional cost for just one room.
As it stands, like previously mentioned, we're removing the floorboards, but would like to get a good understanding of what the best available structural substrate would be.
30 meters Ditra 25 and 60m Kerdi Keba band. I have enough to do the floor a few times over, and probably the walls with it too - but this doesn't seem to be recommended 🙂
Not yet as theres no discounted price atm - but thats easy to get hold of. Thought Id wait until I really needed it or until the price came down in a sale or something. Whichever came first.
But what if I were to say I picked these up for less than half that. Either way, point is not about the Ditra, its about what substrate to use to lay it on.
Awesome - I did have a Google about for this since you previously pointed me into that direction, and also came to the same site, but - Bah! I don't have a trade account, nor have ability to create one, so am needing to try on doors I can access.
Thanks for the link though!
Ditra won
Schluter might be interested to know which retailer you got your materials from, for that price then.
Why spend time taking up the perfectly good floorboards and replacing with WPB ply ....which you will have to cut outside in the open air and most likely have to fit noggins in the subfloor
*Suggest you read original post (link above), their responses and this opening thread again.
I understand this is a controversial topic and agree there is always more than one way to do it. But given the original advice given, not just here on this forum, but elsewhere, please respect the fact that I have opted to remove the floorboards as I have been convinced that tiling ontop of timber is not a suitable foundation - fundamentally for the bounce and wood movement. I accept that overboarding is a good alternative, but as I have the luxury of being able to remove the floorboards, this is the better option from what I have been explained. Why have something adding potential movement when I can get rid of it and firm it up more?
Regarding where I bought my Ditra from - have you never bought something from a friend or accumulated bits over time? I was just lucky enough to be in the right place at the right time, but having it rolling about the house for the past few months isn't great on space.
Now, hopefully bringing this back to a diplomatic point - to reiterate my original post, its about what the appropriate structural boards to use accessible either online or within my area. I have no trade account and am no tradesman in the field so unless Jewson, Selco or [insert favorite trade store here] opens its doors to DIY enthusiasts, then Im out of luck for these venues. The only products I have found to be possible are the listed above.
I would love to hear about what products you all have used in place of NMP under the assumption that they are attached to the joists and not overboarding.
GIFA board does sound like an option, but again am having issues locating a non trade location to access it.
Hope this makes sense
I didn't realize Jewsons was open to all. The GIFA board linked earlier only allowed trade accounts to access and cannot find a price to gauge any comparison. Interesting! Ill investigate further. Thank you.
In the meantime, Im still open to alternate suggestions aligned under the same criteria.
So what are you going to replace the floorboards with?
I was looking for NMP, but cant find it. Open to alternatives, which the only one I can find is from Topps Tiles. Other people suggest a good quality 18mm marine or WBP, but thats lower in my preference.
I've never used those for the use as they are described but, the are a small board and to me will need a noggin under every unsupported edge to the minimise movement you are trying to eradicate.
Exactly. Not a great substitute, plus its quite thick too - which led me here to see what the alternatives are 🙂
So far, it looks like I'm heading towards GIFA boards and badgering a buddy with an account if needs be. But am unclear on the benefits of GIFA vs Ply for this purpose as theres little online documentation on it.
Why not just order NMP boards for delivery? I don't understand why that's not an option?
I ordered a load from putradhesion online without issue (I am also based in London).
Additionally, sounds like we're going down the similar route.... I've reboarded my bathroom with NMP and will tank with Schluter kerdi but gotta fix the floor first. Anyway I'm really impressed with strength of the product for it's size.... I need that strength for the size of the tiles I'm fixing....
I would be happy to order NMP online. I just couldn't find where to get it from. Sounds like you've mastered Google more than me and found somewhere that sells it.
Would you be able to provide a link to the NMP youre using for the floor? The only one I can see on the pureadhesion site is too thin (12mm) - 12mm Tile Backer Boards, tiling board, No More Ply - https://www.pureadhesion.co.uk/no-more-ply-1200x800x12mm-tile-backer-boards.html
If that's the one you're flooring with, is that strong enough? I was looking for at least 18mm - preferably 22mm.
Either way though, sounds like you're going down the same path, so would love to hear your planned specs and end results.
If I can weigh in. If the floor is good then replacing it is a costly move. A product that isn't timber should you do that would give a superior surface to tile however as unlike timber it will not expand and contract. Movement is the enemy in tiling.
Anti crack mats one thing to remember is they are designed for concrete, help regarding lateral movement ie shrinkage. They are not designed to help with vertical movement, the 'bounce' of a timber floor.
If the floor is solid, slightly bias but overboard with 6mm HardieBacker. Again walls we have a 12mm board which sounds like it could be ideal.
I have attached our installation guide which may be of use. Any questions please feel free to contact me anytime on here or 07827 974021.
Regards
Luke
Chris Churchill,
HardieBacker,
Chris Churchill,
HardieBacker,
