I have an outside area to level up and think I will be using Mapei P4, the area is 2.8 long x 1.3 wide and the lowest side is 18mm too low along the 2.8 length rising to a feather at the 1.3 wide mark. How many bags do you think I will need please.
Discuss How Much SLC do you think I need in the Canada Tile Advice area at TilersForums.com.
I have just double checked with my local tilemaster supplier and ther is no problem with bringing back whole bags, so I think I will start with two
Can you please let me know who allows you to take back part used bags, I could make a fortune on my 1/4 bags I have on jobs
Hmm maybe sand and cement for the thicker deeper bits and the SLC from then to the feather. I did notice when cleaning lots of cotton wool type filaments. I think you can get that for normal cement.
Because I messed around with it I had some areas that I needed to take down which are now a bit rough I am thinking of re priming - wouldn't hurt would it ?
I still have another 10 mm -feather to go and I spat my dummy out over paying £60 for 3 bags and its still not level I am thinking of building that part up with extra addy today but that is £15 a bag so wont be saving much.Now you've got the trough filled, why don't you re-level the whole area with SLC and have a nice flat surface to start from?
Well that's far too sensible for me even though I have been in exactly the same situation may times before - gladly paying the extra when i am in up to my neck in it.I can't advise you on specific products, only to say that yes it may be expensive, but if you don't get it flat to start with, in the middle of tiling, you'll wish you had levelled it properly and would gladly part with money to take the pain away!
I have already thought of that- the door opens inAre you going to be able to open your door with all that additional depth?
Reply to How Much SLC do you think I need in the Canada Tile Advice area at TilersForums.com
